i was wondering if anybody could help me regarding the standard plug on an r33 series 2 front indicator..
this is what it looks like:
basically - i just set up the idicators using the green/black wires - am wondering what the blue wire is for..
https://www.sau.com.au/forums/topic/203095-wiring-question/
which brings me to my next question - how would i go about wiring this to be used?
the wiring was cut and i have a custom front bar - so i don't have the orginal lights..
i hooked up the indicators no problem at all - standard wiring - but now i have no idea what i'm doing again..
one wire? hook it up to where? and then what? lol - this is killing me..
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3603997
no dont use it
it goes somewhere else before it gets to the dash as there would normally be a relay for the oem fog lights. if you want fog lights just buy a narva kit with the relay and all and then use the instructions for wiring...
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604013
more than likely the relay will be in the engine bay along with all the other relays
test the blue wire for +ve power when you incar switch is on ... if you have power then the black is a common earth and just tap into that
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604091
yes but the thing is there is a special switch that is normally on the right of the steering colum that is for the fog lights. if your car has fog lights from the factory then the switch is there, if not then the wire should still be there just no switch, that is the trigger for the relay. and if you dont have factory fog lights, then there wont be a relay either...
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604096
ok then Frozenwaffles has given you the info you need.
if your car isnt a S2 that had fog lights - then you will need to setup a relay to supply power to what ever you are lighting up, trigger supplied from the new stalk that you will have to install and wire to the relay .
have fun :P
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604277
ok - i'll start from the beginning.. pretend i'm an idiot.. i have one wire - only one.. that's probably the part that's throwing me off the most.. what hooks up to where?
honestly - this stuff normally clicks.. but it doesn't matter how i work this in my head.. i just can't figure it out.. which is why i'm asking i guess.. :|
Edited by 11toes
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604668
on that plug down in the engine bay, you have a positive (switched wire) for each of the lights being indicator and fog (the fog is the thikler one due to the increased current) and then a common ground or negative. very simple really. if you dont know this then take your car to an auto electrician...
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3604933
and just when i thought i had it worked out..
i fell over at the very next step - i've got my relay - set it up - but to no avail..
does anybody know of a wiring diagram for this? i need to get this figured out before my holidays end :|
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3606467
maybe my issue is with the switch :|
here's an image of the stalks i have - one with the fog switch - the other without..
now - there's that extra plug (presumably to the fog lights switch) - where does that connect?
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3606718
there should be a mating plug somewhere under the dash if you are using the factory loom and relay position...
it will probably be tied up...not just loose hanging around.
if you arnt using the factory wires and all you want to do use the switch, you will need to use a mutimeter to find out how the switch works and which wires are 'switched' if that makes sense...well it makes sense, more if you can understand...:D
anyway i hope you are going well and good luck...things sound a little shakey but im sure you'll work it all out.
just be careful....
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3606727
my only Q from here is about that mating plug..
my car didn't come with the fog light switch on the stalk - i bought that from this forum and attached it.. so will the mating plug be there?
i have changed absolutely nothing else.. all factory (except the end plugs of course which were already cut)
https://www.sau.com.au/forums/topic/203095-wiring-question/#findComment-3606757
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
