Item: Boston Acoustics 12" ProSeries 12.5LF SVC 4ohm
Age: ~4 Years old, I've had it for 2 years, bought 2 off a forum member that imported these himself
Extra Info: check out http://www.bostonacoustics.com/manuals/CarSubMan.pdf
Reason for selling: I have 2, selling 1, want boot space
Condition:
** Top surround has been reglued to basket (common problem)
** Will buy brand new box 1cu box for the sub so its ready to go
** Healthy power fed to it 750watts rms (I had 2 subs in parallel), ran all its life off a 1.5kw monoblock
Price: $220
Contact: PM or 0410 690 248
Comments: SQ sub, goes low and tight... only needs a 1cu box.
To Fit: (What car) ANY CAR!!!!!!!!
Pictures:
Brand New Sub Box
Brand New Sub Box Unwrapped
Sub Woofer Mounting Ring for extra bling
Sub Woofer mounted into box
Edited by johnnilicte
1cu enclosure, tiny!
Sub handles 1kw of real RMS power....!! not for the faint hearted!
Nice sub for a Nice car
Boston Acoustics vs Nissan
Sony xPlode vs Honda
You get the picture!
No one? anyone into Car Audio at all? I already have 1 in my car, used to have 2, just want boot space, so this one is going.
that must of been insanely loud with two of them, did you ever get the spl measured just asking out of curiosity? I'd buy it but I have a 15" Hertz (and no boot really)
free bump
free bump
Wouldn't say insanely loud, wasn't as loud as my 12" Kicker L7 in slot tuned box @37hz, but its heaps more nicer to listen to, the bass is nice and tight and crisps when compared to the L7.
I'm just running one in a tiny 1cu box and it's good enough for me, still gets fed 1kw @ 4ohms RMS though and it loves it.
Well the L7 hit 146db, and that was ear bleeding loud... I have never SPL'd the Bostons, but I reckon both of them would hit 140db+ easy.
Best part about them is they only need a 1cu box, the kicker I used to have was a 2.9cu box LOL
try mobile electronics forum (formally CAA)
tried CAA no nibbles... seems like noone is into car audio much these days...
kids just spend their money on stickers and tow hooks for their Hondas....
if no one buys it, I might get really bored and make an closure for the living room... run it off a Jaycar home sub amp module.
  • 4 weeks later...
I had same sub in my ex's Volvo S40. Running off GT-24 amp (600wrms) got an easy 143db on Termlab in ported box tuned for SQ!! Good sounding sub that can thump.
Good luck with sale.
Man, is anyone into car audio these days?
I have two of these subs. I have not had a chance to do the full installation into the car but did a quick 15 min install to run them at an spl comp. With boxes just sitting and amp leaning up next to boxes I pulled 142dB. That was running off Alpine MRV-1507 (1500W Bridged). These are awesome subs, pretty much indestructible. Worth it for $200 seeing how when they were brand new they retailed for over $800 each.
Cheers
Cheers
I use to run 2 of them at 2ohm off a 1.5kw monoblock... and they loved it... but yeah I'm going for the 1x 12 with moulded enclosure to free up boot space.
So as soon as I 1 of the 2, I'm going to get a moulded enclosure made up.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
