hey guys,
i have been reading some threads about DIY painting FMIC to black.
THings i have done are:
spraying it with etch primer x 1 layer or maybe abit more.
then let it dry. it says 10 minutes drying time (second layer wait for 1 hr) which i didnt read and i sprayed the high temp paint on it after 25 to 30 minutes.
i gave the intercooler a few layers ot the high temp paint. every thing seems nice n paint seems even.
after letting it to dry for half hour(says on bottle - dried to touch in 10 minutes) after 30 or so minutes. i installed the FMIC back into the car. gave it another 45 miuntes to dry.
And i started the car. drove it around n couldnt feel any problem.
been driving the car around for a few days. nothing seems to be wrong...
so what can go wrong?? losing cooling efficiency seems to be wat everyone been telling me. besides that wat can go wrong to the FMIC or even the car?
thanks in advance.
Paint is not a particularly good or bad conductor so it wont make much difference really. You'd have to set up some experiments to confirm that. That said if all you care about is performance, painting it black really can only hamper the flow and heat exchanging. Up to you whether that is as important as the aesthetic or 'stealth' factor.
black attracts heat more so than what the color of aluminium will...something you dont want in a heat soak. I.e. say your in the sun, it will get hotter than if it were just left unpainted-something which will hamper performance. However, it also sheds heat quicker than any other color i.e. say your in the shade or the cooler is well covered then it will lose heat quicker than if it were left unpainted.
Really as stated earlier it makes sweet fa difference to performance. Main factor it changes is the attention you get-good and bad. Its up to you but iv left mine unpainted and it saves you having to paint it every so often after the paint eventually flakes off.
Edited by R32Abuser
Itll slow down the heat exchange rate a little bit (though not enough to worry about unless you put on like 5 coats). If your really worried about it use paint stripper on it and then get the cooler black ANODIZED. Changes the outer layer of material rather than coating it. And it can make it a little bit tougher depending on what anodizing you use. Plus it will never flake off.
Good luck
leewah did this a couple of months back (but he had micolour piant it...) my guess is that he researched the pro's and cons a fair bit before he did it to a 10 sec car
did what, sorry im not sure what you referring to (obviously not the glad wrap idea :banana:), the spraying or anodizing ?
OK, your problem will have uncovered a few other issues you may need to consider (despite all the other replies being full of "dun worry dude, its all good" etc etc etc.
Firstly, your "rice" level has just taken a nose dive big time! You may find that the monster tacho with a redline of 15 00000000000rpm is now completely redundant. This is not cool!
Apart from the complete lack of "fuwwly HeKtIc BrO" you will recieve at the local drive thru Macca's, your chance of picking up "wif teh womenz" will be significantly lower.
The only thing that can save this is a crapload of neons STAT!!!! A GTR badge is also highly recommended, as is a complete shopping list down both doors (bonus "uleh's" if you can slip a random Ralliart or Mugen sticker in there as well.) Oh, no matter what else happens, get a dose pipe or one of those frontal lobotomy inducing BOV's (y'know, the ones you can get from supercheap that are so loud they give you brain surgery unasked?)
Just be grateful that you didn't try this on a Honda - your v-Tec's would be horribly low due to the leakage this influx of stealth would bring!
(BTW, in al seriousness, the colour of your intercoooler will only be affected by the amount of heat it is able to reflect, ie black reflects f**k all heat and light, whereas white reflects almost all - if your 'line is white, I think that would be a much better way of hiding it and not affecting the cooling capacity)
true, but black also disperses heat faster
white fmic would look as ugly as sin
I heard that if its black but properly sprayed so that it wont come off like a can will, it will actually be better for the car as the black draws the heat out of the cooler just like black radiators.
Is this right?
Is this right?
yes, black also disperses heat fastest but it also absorbs it the quickest.
So in a a location like where the radiator is under the bonnet, there is no light contact so black is a good choice to disperse heat. On the front of the car with a big fmic on show, black would absorb heat faster just sitting there in the sun, but once you were driving around it would also disperse heat faster.
Either way it would make bugger all difference in most applications, and the only real reason you would do it is for some sort of "stealth" effect
THe colour of something will only effect its ability to absorb light energy.
White reflects light heat, black absorbs light heat.
So unless u have a 1kw floodlight in front of your fmic, colour don't do sh!t
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
