Well unfortunatey I hit a roo this morning and damaged the LHF guard, smashed the light and some other bits incl the front radiator carbon fibre support. 60kmh 50 yards from holiday home....just jumped from a high block beside us in to my left headlamp.
Killed the eastern grey kangaroo unfortunately.
All the lining under the guard is damaged as well as the left parts of the rad support that supports the light assy. I think that will be a full replacement as not sure they can repair them.
Drove 300km home ok after the Racv guy used a crow bar to clear the wheel. No issues at 110kph so I am figuring all is well mechanically.
I am insured but I was wondering about parts and good repairers in Melbourne...
1. Can infinity headlights be adjusted for RHD.
2. Where can I point repairers for parts other than Nissan au....who say they do list the parts but have to import them.
3. Any good repairers in Melbourne who know these cars.
I am concerned more about availability of parts and quality of repair.
Sad day.
Gibbo
https://www.sau.com.au/forums/topic/203134-ding-a-roo/
She still drives great and 100k so there is nothing mechanical and still gets 9l/100km at that. They are awsome cars to drive.
It was just one of those things the roo just jumped right into my left hand HID headlight. Left it's fur in there and buggered the globe as well.
Had I not just been 50 m from my other home but on the open road it could have been much much worse and the car would have probably been totaled. Fortunately the air bags did not go off.
Regardless of opinions I am going to invest in an ultrasonic shu roo device as I have one on the 4wd and never hit a roo ...I figure that would have may be been the only thing that could help. Second roo I have collected the other one at 90kmh and that one flattened itself across the entire front bumper of my SS with almost no damage to the car.
So glad it was not a person but sad for the roo as it had a very young joey in the pouch... and I am one of those folks not that happy about culling.
Thanks for your thoughts.
***** Hey ...Can the USA headlights be used for Right hand drive cars (I'd doubt it). $600usd in USA $5000au via Nissan go figure.
https://www.sau.com.au/forums/topic/203134-ding-a-roo/#findComment-3605491
I wish they were and would like tom find out for sure first.
As Chris says the lights have a 15 degree offset to the passenger side in each country so that would mean the US ones would need to be ale to be adjusted 30 degres to the left. If they can then sweet it opens up a huge cheap market for us - $400 ea (plus shipping) rather than the $2500 each Nissan charge.
Can anyone confirm if this is possible please?
Gibbo
https://www.sau.com.au/forums/topic/203134-ding-a-roo/#findComment-3605570
Hi I was in the process of getting lights from the US, and Chris is correct (is the guy ever wrong) about the 15 degree adjustment, so there is not enough adjustment on the US lights to stop them from pointing towards on coming traffic. The place that complianced my car confirmed this as well. Frank bought the 2006 lights on his car. He can probably provide a more detailed account of the upgrade.
cheers
Edited by vspec2
https://www.sau.com.au/forums/topic/203134-ding-a-roo/#findComment-3605866
  • 1 year later...
    • Sometimes you need to pay good money to get quality work done.
    • I found they are significantly more expensive than other workshops (this is when I went to ask about a tune), heard they are good though.
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
