Hi fellas,
Just bought a Series 2 Stagea last week. Not long after, I took it to get a stereo head unit and alarm system fitted. When I collect the car, the auto box is messed up!!! It won't shift to fourth gear / overdrive. I had to shift to tiptronic mode using the gear lever and 'force' it to shift to fourth. If I move it back to 'D' it shifts down to the third gear and will not shift up. Also, the tiptronic button on the steering wheel does not work now.
Took it back to the guys who installed the alarm and they have no idea... FYI, I've fitted an AutoWatch alarm system with the turbo timer...
Please help!!!
Hi fellas,
Please help!!!
if you bought it of a dealer and have got warranty your gunna take it back...... i've got a s1 so don't know if theres a little trick...s2 guys will help there.....sorry i got no idea, hope someone else can help, good luck,
fingers crossed for warranty
leigh.
There could be a couple of problems, compounding the situation, or could be something else entirely.
One, I wouldn't suspect the box, until you've looked at everything else.
1st, I'd check fuses, BUT... I'd be suspicious of wires that may have been cut or tampered with under the centre console.
The tipronic switch, when pressed will show a light on the dash (near the speedo). If nothing happens, then suspect that the switch may have been disconnected.
Also have a a look at the other buttons.... see if you have the "Snow" button.... this engages the box at 2nd and misses first.... I don't know if it affects 4th gear.
I would think that the problem is under there somewhere. They may have used a feed pick up for the radio, that they shouldn't.
I was just wondering if it goes better on FM or AM..... just kidding.... I don't think that it is major, but may take some sorting out.
Good Luck
leigh.
Yes... I do have warranty from the dealer. Have arranged to see them next Wednesday. :rolleyes:
Good Luck
Thanks, I'll ask the service guys to look at the wiring under the center console first.
I did try to use the steering wheel buttons, but I didn't see any light comes up. If you're talking about the light that shows which gear I am in, it does show though.
I do have the snow button, I'll check whether it will affect the 4th gear. There is also a button that looks like a steering wheel right next to the shifter, I'm not sure what it does.
Also, what do you mean by using a feed pick up for the radio?
To use the tiptronic function via the steering wheel controls you have to turn the switch next to the auto shifter to "ON".
This switch has a picture of the steering wheel on it. When you switch this on, there will also be another light that comes on in the dash. The dash light also has a picture of a 'steering wheel'. It is a different light to the one that shows which gear you are in.
This simply means that you can change gears via the steering wheel buttons when the dash 'steering wheel' light comes on.
With the button "ON" you can choose to change gears manually with the steering wheel button or the shifter (move shifter to left position).
Give it a go and see what happens. Hope that helps in some way.
I mean that they might have done it the lazy way and cut into one of the wires that controls the tiptronic in order to get power for the radio... thereby stuffing the auto about..... I don't know I am only thinking out loud. But worth checking. The button next to the shift is as Stagman describes it.... I would be looking under the console in this area first. The other thing that is possible..... is that the shift lever is now somehow out of alignment, and isn't really going into D.... maybe it just looks like it is.. and it is actually in 3rd.... that'd do it....maybe they didn't put the console back together properly, the more I think about the more likely it seems.
Thanks, I'll give it a try...
You could be right, maybe they cut something out. I heard them talking about pulling a loom that "doesn't seem to do anything"... With the shift out of alignment, it sounds like a mechanical problem. But worth a try.
Anyways, I'm not going to touch the car because I'm not a mechanic. I'll wait until Wednesday for the dealer mechanics to have a look at it, and I'll give him all the suggestions.
If anyone else can offer a suggestion, please don't hesitate...
There is an Auto ECU fault code diagnostic mode as well, flashes the code via the A/T dash light, bit tricky to activate, but have used it before with success. Dont have it on hand, can post it tonight if you are interested.
Edited by chook
Yes, please do... Any suggestions's a good suggestion >_< What does it do though?
If the ECU detects a fault, it will store it in its memory, when you perform the diagnostic test it will flash a code, check the code to the list, which ill provide, and hopefully will steer you in right direction.
Can be done for ECU, Auto ECU, Hicas, Attessa(4wd).
Sounds like your alarm/stereo installers werent too skilled.
Where are you located ? Wouldnt go past Chris Rogers for these type of installs in Brisbane.
Edited by chook
If the ECU detects a fault, it will store it in its memory, when you perform the diagnostic test it will flash a 2 digit code, check the code to the code list, which ill provide, and hopefully will steer you in right direction.
I'm in Perth... Well, the dealer recommend me to go to them for the alarm. Seeing that they have stereo systems, I went and bought a new head unit as well. What a mistake it turns out to be.
Hi, after having another think about it. I forgot to ask if the auto is showing "D" on the dash.... if it is, well then it may need more sorting.
Where in Perth are you? I am in Coogee, feel free to PM me if you want to have a look at anything in mine.
I don't like the sound of that "loom that does nothing"!! Car manufacturers don't put very much in any car if doesn't have a purpose.
You just reminded me why I don't like other guys installing things...
Best of luck on Wednesday.
Just another thought.....have you checked the snow button to see if it is on yet?
If it's on, it will make you take off in second gear, as others have suggested, and you should only 'feel' two gear changes...2-3 and 3-4 in normal non tiptronic mode, so you think your are in third gear but actually in 4th as you take off in 2nd gear.
What are your revs at 100km/hr in top gear?
Turning the 'snow button off' should get you taking off in first and then feeling 3 gear changes before you get into top gear.
Thanks... I made sure I turn the snow button off. Just to make sure, I turn it on and tried launching... Sure enough, it accelerated very slowly (so definitely not the snow button). I also tried using the steering wheel tiptronic instead of the gearshift, and it works fine as normal.
My revs at 100km/h in top gear is just below 2500...
So, thanks to all the earlier suggestions, I managed to narrow down the problem only in the auto "D" mode.
I really cant believe no one has mentioned this yet, but I'm willing to bet you have nothing wrong with your auto box.
The default behaviour of the Stagea auto (not sure if its the same for s1) is to not engage 4th gear until you either go over 80km/h or until its warmed up enough. So when cold it will not engage 4th at all, until it warms up - often about 2-5 mins into the drive...
It wont let you force 4th gear in any way other than going over about 70-80km/h...and in that case the auto will warm up fairly quick anyway...
I only noticed this when I got an exhaust fitted - because this made it way more noticeable. I could tell something was different before but hadn't put it down to which gear it was in.
you will also notice the car is not very responsive until the engine is warm anyway, which can take longer than the gearbox to warm up. I usually keep an eye on the temp guage and just go easy on the throttle until the needle is horizontal. You'll notice the car suddenly ease up and drive more smoothly once it warms up. It runs fairly rich when cold so probably switches to another fuel map once its warm or something like that.
We probably should have a page of info full of little stagea quirks like this one. I only found this out because it was in the little book I got with the car from the dealer. ;)
If it wont do 4th even when its well and truly warmed up, then maybe you have a fault? in that case, take it to a qualified auto transmission specialist who can open it up and fix it. Hopefully its all fine though...
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
