Hey all just wonderin if anyone has ever had any problems with a Jim Berry?? Just helpin a mate pull his out of his GSR and it is to put it simple farqed
Hes had it in for bout 12 months or so and the car was off the road for a few months gettin an eng rebuild
My house mate and i are running Jim Berrys as well (in a rs liberty and a 33) and have had no dramas
https://www.sau.com.au/forums/topic/203153-jim-berry-clutches/
  • Replies 62
Waits for Shanef...........
Got one in a GTIR, caned as required, been in there at least 2 years, since install upped turbo/boost, added Pfc in the interim, 172kw@4wd nf'n prob. My boy said clutch goes better/smoother with more power available. Has the owner talked to Jim? Rules are you gotta tell Jim what power you is aim'n for & his clutch packages are built accordingly.
My 2c
Cheers GW
Nothing wrong with Jim Berry clutchs...
Have run a couple of them now and never had an issue...
There would be less than 0.1% chance the clutch was faulty, as a faulty cutch would break within minutes/hours not 12 months...
Although it might be worth going to see him with the clutch as he may hve an idea as to why it failed, he is a bloody smart man...
Yeah, agree with you all i've never had a problem with mine (except for adjusting to it) and my house mate hasn't either
He told Jim what kinda power outputs he was lookin at and stuff
Found out just today he spoke to him and supposably there is a fault in the drive shaft being to long and no having an adaquet bush/ bearing at the other end to support it and thats what caused the problem
I have had a jim berry clutch in my 33 for a few years. My car has made 399rwkw and have never has this thing slip. When the clutch was built it was 3800lb clamp force and rated at 380kw.
From a standing start i could drop the clutch at 8000rpm in 3rd gear and turn the tyres in to clouds of smoke.
The main thing I was told was to use graphite powder on the gearbox spline and i always took my foot off the clutch when stopped at traffic lights. If I was staying with a manual i would certainly buy another suited for my new power level
I've got one in my car but it was only built for small power, didn't get the full blown clutch he normally does for most people. Only complaints I've got are the clutch makes a ticking/clicking type noise when down changing, and also my car now makes a really awful grinding type noise when driving at 2,000 rpm in third or fourth which is quite annoying because 2,000rpm is roughly what RPM you do when doing 60klm in 4th gear. Not sure if that problem was a result of a poor install or if it's because I didn't get a full blown clutch like many others.
  • 5 months later...
What type of 'JIM BERRY' clutch is it and whats it worth?
PM me if you want
Thanks
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
