  • Replies 62
Wake up to yourself. You cannot say that these clutches explode universally. There are thousands of happy customers running these clutches. Do a search if you need any further clarification.
Ignorant, second hand information always comes free. Whether you choose to listen to it is another thing altogether.
the only failures ive heard of have been due to the flywheel...when running a higher than STD clamp rate its advisable to have the flywheel crack tested for flaws, as they are cast iron...running a billet item with these clutches is what id recommend.
Unfortunately the actual pressure plate let go on the clutch mentioned above. There was also an excedy chromoly flywheel on there aswell, the only thing that stayed attached to the engine, the rest exploded and tore into a zillion pieces. It let go when the car was stationary, the revs brought up to get the MT's warm and upon the clutch engaging it exploded.
See here for details: http://www.skylinesaustralia.com/forums/Cl...on-t233996.html
The only problem with jims clutches is the fact he re-uses the std cover/pressure plate which is NOT anti-burst, and IMO that just isnt good enough.
Horse shit. He absolutely does not re-use the std plates for appropriately specified clutch assemblies. If it was spec'd for the task at hand then it wouldn't have used a stock pressure plate and wouldn't have let go.
Sounds like someone wasn't clear with what they were doing with the clutch. Even so, freak accidents happen that are out of someone like Jim's control such as manufacturing abnormalities but no more here than for any other manufacturer.
Generic statements like the one above and the first comment made in an earlier post that implies all of these clutches explode are damaging to Jim's business and whether or not they are without basis is beside the point. It is abundantly clear from the sheer weight of numbers of people happy with their Race Clutch that they're a good thing almost all of the time.
If anyone needs further clarification, I suggest they call every clutch manufacturer they can get a hold of and ask them if they've ever had a failure. If you find one that says they haven't then I'll eat my words.
what else is horse shit is again ur severly un-informed and jumping to conclusions. The clutch was ordered specifically to handle 900rwhp and slick tyred drag duties also with every now and again street duties.. It failed with a measly 510rwhp and MT ET's.
The fact remains it wouldnt have exploded the way it did if an anti-burst cover/pressure plate was used.
I know theres always going to be the odd failure but if any possibility of failure can be removed and it's not (say by the use of higher grade materials), then the only person to blame is the manufacturer.
Even if communication went wrong along the lines somewhere as to what power rating and application was intended. What are the AS on clutch covers?? Personally I don't know, just wondering if anyone knows.
I'll break this down into point form for you so it's easier to understand:
FACT:
- Not all Jim Berry clutches use remanufactured pressure plates
- A very tiny percentage of Jim's clutches have had failures
- Most of these failures have been as a result of other factors (flywheels letting go etc)
OR
improperly spec'd clutches due to customer supplying incorrect information
- Jim is one of the easiest guys to work with and actually has an interest in fixing any problems as they arrive
FICTION:
- All Jim Berry clutches explode
- All Jim Berry clutches use remanufactured pressure plates
- All Jim Berry clutches are inferior to other brands
- Jim Berry clutches are unsuitable for use with standard flywheels
- "They can't handle xxx horsepower"
The issue is with general statements that appear (to normal thinking human beings who walk upright and can walk AND chew gum) to apply to all Jim Berry clutches. It is unfair, incorrect and potentially libelous to suggest that the failures mentioned apply like this.
See? It's simple.
(to normal thinking human beings who walk upright and can walk AND chew gum at the same time)
fixed
go easy on him 2rismo...he's got issues....
not only does he have to live in QLD but he also has to put up with a car that is powered by a forklift engine.
Just like the RB30 powered heap of sh1t below
Edited by DiRTgarage
FACT:
OR
FICTION:
See? It's simple.
All u achieved there was expanding ur previous post into dot form.
Should i try?
fixed
aww come on pauly play nice. Maybe i should just put some HKS stickers on and then it'd be the best thing since sliced ham?
so in conclusion
2rismo is right in saying that blankets statements are bad
Shane is right in saying that this particular clutch was a massive fail considering it literally exploded in an application it was designed to handle easily
Yay every one wins
Obviously it didn't work. If you're not going to pay attention I wont bother. It seems the user that posted "they explode" doesn't feel the need to get defensive over my post. Maybe you should follow his lead.
EDIT: Bunta, sounds good champ! :D
Guest
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
