Hey just wondering who sells rims that have the oily coloured lips (like when you see oily water on the road. . all the colours) or anyone in perth that can do that effect to some rims i like
Im after 19s or 20s and AT LEAST 100mm of dish on the back, and gloss black spokes
Cheers
Daniel
https://www.sau.com.au/forums/topic/203210-rims/
your talking about titanium polished dish
how much you wanna spend????
there are some cheapies going around but the original ones are Rays
Yep thats the look i want . . Im guessing there expensive then? Im after black spokes with the titanium lip. .
MMMMMM love that lip
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3604900
last quote i had for em in 18's was 4200 with plain silver centre, black centre not available when i was looking also and a 5month wait
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3605409
Bugger . . I dont really want to wait that long just for rims . . 2GU UP do you know anything about the cheapies you said that were around? Or anyone know who can do that effect if i take rims to them in perth?
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3605781
those rims there, I heard that if you damage it..the rim repair places cant fix it..lik they can fix the whole rim but you'll loose the titanium colour effect..
so any scratchs on em guess you needa leave it or buy a whole new rim..
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3606078
Dam . . that sucks ;)
Is it some type of coating or is it done buy heating the rim up to get the burn like heat marks?
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3606177
yeah titanium wheels are hard to machine and has lik a really high melting point..
but then agian..titanium wheels are only good for show because there heavy and weak...easily damaged ay..so no point riskin big $$$ and getting it damaged after a little curb
my mate should be getting his set in soon and see how that goes..but only thing is..his keeping it for show so wont be awhile until he puts them on.
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3606310
Arnt fighter jets made from titanium . . so they are light and strong?
Anyway i want some of those rims but not too keen on waiting for ages for them to arrive
Had a look on the site and the biggest i saw was 18s :D I WANT BIGGER lol and wider . .
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3607041
Titanium has the highest strenth to weight ratio, hence why they cost $$$$. They are lighter than the other rays rims which are already lighter than most.
Cheap brand titanium rims will be heavy because they are most likely a titanium alloy and like all no name brands will have to be thicker to cope with the forces exerted on them.
From Wikipedia
The two most useful properties of the metal form are corrosion resistance, and the highest strength-to-weight ratio of any metal.[4] In its unalloyed condition, titanium is as strong as some steels, but 45% lighter.
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3607344
Ah i see :banana:
Im not really worried that much about the weight of the rim, like i dont want something as heavy as a fridge lol . . They would just be for street use . . and put the stokies on when at the drags (when i move back to perth) Just want something different looking and you dont see that lip anywhere. .
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3607368
I say spend your money elsewhere...
I seriously never did understand how someone can willingly put that amount of money into rims, when they do the same thing the previous ones did...
rims are the ultimate in rice and waste of money...
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3609266
haaaaaaaaaahahahahaha titanium heavy and weak!!
Thats some funny shit right there.
Oh dear.
People regard titanium as being some sort of brilliant material. It is not necesarilly that good. Its best properties aren't so much its strength per se, but its corrosion resistance, toughness & high temperature strength. Most of the titanium mined in Australia is turned into white powder, not alloy.
In any case I think you will find that the rims are aluminium and simply coated in Titanium which give them the rainbow effect. There is no reason for them to be any heavier, stronger, weaker or substantially different than any other Volk rim.
https://www.sau.com.au/forums/topic/203210-rims/#findComment-3609339
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
