For sale I have a 1978 Datsun c210/240k skyline
Its powered by a L24 which was remanufactured 60,000 ago including remachined head and bottom end , it as sinse been rebuilt including new gaskets and macining about 10,000 ago
It as a stock Lsd diff and strong 3speed trans wich we're rebuilt 45,000 ago
The car has been sprayed and registered as black
It makes a few noises as any old car would but runs perfectly and starts first kick every time
Ignition as been converted from a points setup to a MSD electric Dizzy setup
Its running some sort of exaust system which was on the car wen i bought it , not sure wat it is but its farely loud down at low rpm
Carby as been rebuilt around 5,000kz ago gaining it better economy
This car as great turbo/drift potential and is easy to find performance parts as is same motor as 240z
I am asking 850neg and i am located near TTG in SA
send me a message if you are interested and i can email you pictures
I would also consider swap with cash adjustment for r31 ect....
https://www.sau.com.au/forums/topic/203211-fs-sa-rare-c210-skyline/
I have heard that this car is actually a Mitsubishi Sigma. Please confirm that this is not some kind of sick joke. Do you have a Skyline for sale or not?
By the way, the C210 and the 240K are two completely different cars, and neither came out with a stock LSD.
sorry this is off-topic means13... but looking at your email addy.....do you also have a DR30?? if you do and and in SA bring it out next cruise mine is getting lonely :(
  • 3 weeks later...
by the way things are going i mite be selling my C210 ,
80K with log books but heck knows if the KM are real
shes alright drives smooth as in engine / trans wise /
all she needs done is new tie rod and unbend a rear suspension arm but you mite as well just buy one
reason for selling , don't have the cash to fix it
i would be looking at about $1500 , but any $800 or whatever cash offer would do
pics can be found in the classic section
this is just out of interest if i cant get a job with in the next few weeks.
i bought the car for 2.5K but a few strings of unfortunate events have f*ked it up sigh , i love the car if it wasn't for the rear suspension arm and front tie rod i would never have the thought of selling it
by the way as i stated just out of interest
Edited by Rice_banger
I was the one which saw the sigma , i went there and there was no C210 , only a sigma 2.6 new school , i contacted the OP of the thread to confirm to everyone it was a waste of time / space and he said he lot password
by the way i just hijacked the thread above only out of interest.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
