Make: Nissan Skyline series 3
Model: r31
Milage:223***kms
Transmission: factory manual
Colour:white
Complied? yes
RWC supplied? na
Currently registered? yes
Price: $2100 without stereo $3100 with
Contact: Call/Msg Matt on 0411781741
Comments / Modifications: 220,*** k's
has not missed a beat
manual
isotta steer wheel (legal) and gear knob
well looked after
always run on 98 octane
prized possession
viper talking alarm, interior and exterior sensors
central locking
extractors
sports muffler
lowered with king springs at the rear
5 spoke white 15" mags with ok tyres
Images:
$3100
with
sound system includes
2006 jvc dvd screen
polk momo carbon splits
polk momo db rears
polk momo 15 inch sub in a ported and tuned box, can be used for spl
eclipse mono block 480w rms amp.
eclipse 2 way 2x100w rms amp
paid over 3k for the above
im asking 1k on top of the car price. you will be happy once you have heard it.
$3100 all up.
price drop of $1000 off both prices with and without the stereo
CAR SOLD
Edited by Love_Hate
https://www.sau.com.au/forums/topic/203268-sold/
  • 3 weeks later...
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
