Hi guys,
I've done some research and I want to buy a GT-RS turbo.
However, I was concerened about the lag issue.
Could the people who have a GT-RS turbo tell me when they hit full boost (at what RPM) and what boost they are running?
I am aiming to get around 240RWKW from my car.
Current mods include:
Full 3.5" straight through exhaust
GReddy Front mount intercooler
Splitfire coil packs
Power FC
Bosch 040 Fuel pump
Cold air intake system with pod and heat shield
Boost controller set to 12 PSI.
Currently, my car is putting out 195 RWKW with the current mods. Should I be able to reach 240 RWKW with the GT-RS with bigger injectors (550 CC)?
I've also read about the HKS 2530 but I read that it only could pull out about 220 RWKW. Is there a turbo that is in between the GT-RS and the HKS 2530 and that isn't so laggy?
Cheers!
This was on my previous set-up (rb25)
- Tomei cams
- Head porting
- std exhaust manifold
- std plenum
- 3" turbo-back exhaust
- 550cc inj
- Wolf3D V4 ecu
- and all other supporting mods
(ignore the red line)
Guest
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
