I wouldnt bother to be honest. Sure it will look different but its going to cost you, and surely that cash could be well spent in the braking/suspension area instead :ermm:
I've got my spring rate and dampening just right, and I've upgraded to R33 GTR brakes all round. ATM the outside of the car looks like poo, but the internals and handling are ace.
I'm not big fan of huge widebody kits anymore, after driving a kakimoto R33 with 355's on the back for a while on the street. Plus the streetability of a widebody kit is non existant, which is why I sold my original BN Sports kit.
The flares are so I can go a little bit further up from the 8" wide GTR wheels I have atm, and also to bring the look of the R32 up to speed with current designs on cars.
URAS, I've found fender flares in japan and can import them as well... I'd rather just find a local fibreglasser who's making them so I can just grab a pair, and see what modifications I'd have to make to blend the factory lines in with the flares.
I have a set of Work VS-XX's with B disc centres, which clear GTR brakes, sitting in my garage... sif put drifteks on a car. Did a 235/45/17 stretch onto the 10.5" wheel for shits n giggles. Might end up having to buy 265's or something.
I remember seeing a post from an r32 gtr owner saying he has 10.5's under the guards without dramas (no doubt lipped though).
Oh well, time for monkey to spend some cash and import some fenders
Went thru some of my old mags and found an ad for a chargespeed overfender kit for R32 GTR's. Perfect. They'll look so baller when colour matched and blended into the guards.
That last post. looks chunky cause it goes all the way down to the bottom on the rear. Not sure if thats a good thing or bad.
Love the rims and the dish :)
The one with the white 32 looks good. Nice and bold. Just the arch.
Not sure what "look" your looking for though.
Honestly not a fan of the ones that go all the way down.
I reckon the ones Nismo Boy posted would look alright if it was all complete. Thought it would look shit, but doesn't look too bad.
Love the Equips on the 180/240 though. :)
Edited by adam-__-
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
