Hey guys and girls
I just sold my rx7 because it was a petrol hungry beast, am now looking at a 34 non turbo
anyone know much bout them?
looks nice but is it good on fuel??? ive had enough with the petrol hungry cars looking for something more tame.
any suggestions or tips about the 34?
https://www.sau.com.au/forums/topic/203276-r34/
Hey guys and girls
The Term "Petrol hungry cars" can be very wild, so in your standard how much Litre/100kms is too hungry for you mate thats the question.
So if you want a car that need next to nothing to run buy:
"Smart 4 Two" A.K.A Smart-car
Echo
Yaris
Getz
Swift
If you don't want a small or a compact car but yet uses less fuel then:
Camry
Aurion
VE commodore
Accord Euro
New lancer
If you want a car that have a sporting looks or go fast feel but yet retain some sort of fuel economy then:
Mini
FTO
Civic Type-R
Integra Type-R
350Z
Non turbo Version of R34,R33,R32, WRX Rs, Supra
Edited by MRR34
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3605711
if you can keep your foot out of it and drive sedately it will be MUCH better than a rotor.
I have a wagon that will chew 60lt of 98 octane petrol in 290k if I drive it wild. sedate it will do 550 on the same tank.
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3606416
a 34 NA is no more fuel guzzling than a 6 cyl commodore...and should definately be much better compared to a rotor.
althought my mrs gets 500-600 a full tank fuel using the cheaper ethnol blends.. FYI the NA auto RWD dynoed at 160hp @ rear wheel this is after a major service and tune as well
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3611720
They are decent for a six cylinder with mine getting about 10liters per 100kms on average, thats better than my 2006 hilux ute which is a 4cylinder. I wouldn't waste your time getting an na (thats wat i have) nice car and all drives great, but is pretty slow and also don't get an auto (extra slow). A manual might be alright, but power wise i raced my old r31 manual with just extractors and exaust against my stock auto 34 and there was nothing between them, over 120km the 34 would flog it. You would probly get a bit better fuel economy out of the manual version as well.
Edited by turtlepower
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3623391
  • 8 months later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
