Hey guys and girls
I just sold my rx7 because it was a petrol hungry beast, am now looking at a 34 non turbo
anyone know much bout them?
looks nice but is it good on fuel??? ive had enough with the petrol hungry cars looking for something more tame.
any suggestions or tips about the 34?
https://www.sau.com.au/forums/topic/203276-r34/
Hey guys and girls
The Term "Petrol hungry cars" can be very wild, so in your standard how much Litre/100kms is too hungry for you mate thats the question.
So if you want a car that need next to nothing to run buy:
"Smart 4 Two" A.K.A Smart-car
Echo
Yaris
Getz
Swift
If you don't want a small or a compact car but yet uses less fuel then:
Camry
Aurion
VE commodore
Accord Euro
New lancer
If you want a car that have a sporting looks or go fast feel but yet retain some sort of fuel economy then:
Mini
FTO
Civic Type-R
Integra Type-R
350Z
Non turbo Version of R34,R33,R32, WRX Rs, Supra
Edited by MRR34
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3605711
if you can keep your foot out of it and drive sedately it will be MUCH better than a rotor.
I have a wagon that will chew 60lt of 98 octane petrol in 290k if I drive it wild. sedate it will do 550 on the same tank.
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3606416
a 34 NA is no more fuel guzzling than a 6 cyl commodore...and should definately be much better compared to a rotor.
althought my mrs gets 500-600 a full tank fuel using the cheaper ethnol blends.. FYI the NA auto RWD dynoed at 160hp @ rear wheel this is after a major service and tune as well
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3611720
They are decent for a six cylinder with mine getting about 10liters per 100kms on average, thats better than my 2006 hilux ute which is a 4cylinder. I wouldn't waste your time getting an na (thats wat i have) nice car and all drives great, but is pretty slow and also don't get an auto (extra slow). A manual might be alright, but power wise i raced my old r31 manual with just extractors and exaust against my stock auto 34 and there was nothing between them, over 120km the 34 would flog it. You would probly get a bit better fuel economy out of the manual version as well.
Edited by turtlepower
https://www.sau.com.au/forums/topic/203276-r34/#findComment-3623391
  • 8 months later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
