Guest Boxhead
ok Guys just thought i would post somethings on what pete smith and i did to my motor vehicle.. thats right we put a cold air intake on it...
basically made it from PVC piping.. when teh car is started you can actually feel the intake sucking in the air..this is with a stock airbox, with a no name air filter...
as you can see in this pic a hole has been cut in teh bottom of the airbox and with 90mm has been joined and flows down through the metal. which was cut to fit.
https://www.sau.com.au/forums/topic/2033-cold-air-intake/
Guest Boxhead
and this is from the front, the intake next to the fog light.. since this pic, i have flared the end of the pipe, its done just with a lighter heating it.. so it flezes very nice, and then just use anything to hold it for a minute or 2 and bingo.. i will make it fit better when i get the front bar off to fit the mesh, to protect from anything getting in there.... i will have another pic soon when the mesh is on
https://www.sau.com.au/forums/topic/2033-cold-air-intake/#findComment-37644
my bro-inlaw is getting his brother to make me a stainless steal one that goes from where it needs to be connected on the engine, right down to the bottom of my front bar (i have a 400r replica bar so near the bottom is a meshed spot where air is just taken in nicely)
https://www.sau.com.au/forums/topic/2033-cold-air-intake/#findComment-37978
| hype ^ | I'm following this path with my R33 at the moment but am using a GTR intake instead of the stock one , it flows about 2 to 3 times as much air. I've diced the standard air box all together and am using a pod filter and fitting the intake into the top of the new cold air box which is basicly a partition to close it off from the engine bay and a lid which the intake fits into. You get quite a lot of air in around the headlight too and a ram tube down to the front bar is not needed..... at least not until you get up around 600 700Kwts. I'll post a couple of pics in this thread tomorrow of the cardboard one i'm using at the moment. Also I'm using an EMS computer so have diced the air flow meter as well.
https://www.sau.com.au/forums/topic/2033-cold-air-intake/#findComment-41661
Tropo: thanks for that, but still not what I'm looking for. That is a cold air box for a pod filter, I wanted to make a cold air feed for the standard air box.
Meggala: I had a look on your site, but couldn't find anything... Anyhow, its a easier for the R32, b/c the air passes from bottom to top, so you could easily cut a hole in the bottom section to put another pipe in. The R33 is top to bottom, and there isn't much room on the airbox lid to slap another pipe in...
Thanks anyway guys :)
GTST: Did you manage to find the link, or was it the same as the link that troppo posted?
Zahos
https://www.sau.com.au/forums/topic/2033-cold-air-intake/#findComment-41712
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
