Yeah I wanted to come, but my missus has my balls in a bun now organising our engagement and wedding.... and worst of all......
It may be a girls best friend, but it is also mans worst enemy........
The diamond ring!!!!
Think about what I could do to my car with that money I'll be spending on that ring!!!
hey guys, recently i've put in a cold air intake for my k&n pod filter. don't notice any real performance gains, but i did notice that my bloody petrol meter drops a lot faster! fuel consumption has gone worse. does this sound right?
then i planned to put the stock box back and give it cold air intake and realised what Zahos has mentioned.
The R33 is top to bottom, and there isn't much room on the airbox lid to slap another pipe in...
i couldn't drill a hole through the stock box for the cold air intake.
btw, i don't have a heat shield or cold box, would this be the reason, because its still basically just sucking in hot air? CAI is just letting more air in and mixing with the hot air so the pod is sucking in more hot air?
also, my car is NA :D
  • 1 month later...
For R32, it is a very easy mod! you just slap another pipe into the bottom of the box to get more cold air.
The R33's flow air through the box in the oppisite way, and the lid does not have much room for a pipe to be put on, hence my plans to modify it!
To clarify for those wondering the difference, here is another pic showing the differences.
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
