22" Forged On A R35.... "droooooolsssssss'
Gazzilla
 Share
IFORGED PERFORMANCE ALLOYS RELEASES THE WORLDS FIRST 22" WHEEL APPLICATION FOR THE NEW NISSAN SKYLINE GTR
ANAHEIM, Calif., January. 11, 2008 – iForged Performance Alloys becomes the first wheel manufacture in the world to release a 22" wheel application for the new Nissan Skyline GTR. Two Skyline GTR's showcased the new 22" wheel fitment at the 2008 Tokyo Auto Salon. The Skyline GTR custom wheel fitment was a collaboration effort with Nissan Motors, Brembo Japan, Auto Technik Japan, and iForged Performance Alloys.
'what is that in my pants! :)
  • Replies 72
Personally speaking... I find the stock R35 GTR rims look more tough... that's just me though.
Those rims look pimp as (bling factor)! How much better would they look if the fronts had as much dish as the rear; just like previous GTRs.
I'm sure other manufacturers are working on new rims for the GTR.
I still like the std rims; so far the best looking factory rim to come out of the Nissan production line
Expect a LOT more of this... baller is the way to go to sell cars these days. The 300C was the first car to sell itself on big diameter wheels, Nissan have just copied a winning idea.
Think about what we have. An automatic, big wheel, big power, hitech Mustang with Nissan Handling and build quality.
Agreed on the Ferrari look, other people may not, but they probably don't realise that virtually every Ferrari in Japan is white.
100% agree. This will be massive in the states. 22" + rims and chopped springs. It's a shame.
I really would have thought that with the size of the brakes on the R35 Nissan wouldnt have had any other choice than to fit 20s to it...
As for those pics :D
Nissan has copied jack shit. There's a performance reason why they went for 20's, like there is a performance reason Porsche went with 19's for the 997 Turbo. They're not thinking, geez, this will get me in the good books with 50 cent :D
*sigh* they just don't get it. This is such an aesthetically "japanese" car, i mean, the head designer was referencing anime/manga for goodness sake! These crappy 22's work on euro's, but they DON'T work on such a japanese styled car.
Rims are shit
I'm not surprised they've got to 22s already, those stock tyres were something like 248/45/20 which is still a very high sidewall. I can't be stuff doing the maths but even 23" might be possible with the right tyres.
good luck finding decent tyres in 245/??/22.....probably custom?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
