hi guys. after recently sticking in a forward facing plenum my car does not inject fuel.
when on, the pump still wirrs up, fuel fills the rail, and it doesnt seem to be going through the injectors. fuel remains at 60psi ish, proving that fuel is in the rail....but thats as far as it goes. have checked the circuit, all is fine. i have also checked the ignition, aac valve, afm and it is all fine.
the car still cranks, and it really wants to crank over, but it only partially catches and doesn't idle.....IT IS SOO CLOSE. so far we have definitely narrowed it to the fuel injection system.
i just wanted to get your opinions before i went to a mechanic/electrician. i am getting pretty pissed because it has been off the road for a month. at the same time i also installed a gt3540 with .82rear, custom h/m manifold and tial wastegate. and all the plumbing for that is perfect.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/203363-fuel-injection-problem/
does it start any better if you hold the throttle a little open?
checked all the common fuses etc?
do you hear spark properly? screwdriver on the head & listen to it
have you changed or modified the TPS in any way?
what ecu? what diags does it have?
Nice turbo choice :(
60psi massive, ~43psi is base pressure btw.
Usual checks, are your plugs wet? if so, are you get'n spark? Checked ECU for codes? Tried disconnecting AFM?
Start from the bottom and work your way up. If you haul it to a shop and let em know you've done a full turbo swap in your garage, they will charge you through your ring. That said, if the above is all you've tried.. maybe leave it to somone else :D truth
EDIT: dammmmmit i need to learn to refreash a window b4 posting
Edited by GeeTR
lol respect.
stock management....emu hasnt arrived.
yea..when fuel is let into the cylinders when the injectors are out, the engine starts for a few sec. but atm it is starved of fuel..but injectors are fine, have a circuit and are clean.
it cant be an injector fault. what are the odds of all six going?
pressure is high because the fuel isnt going anywhere, this is my problem
but i will try disconnecting the afm.
+ i put in my other injectors and they arent firing ????
so i think its electrical but i cant find the problem.. but it is getting power and everything.
remove the rail and put a large rag down over the motor, then remove the CAS, turn the ignition on and spin the cas. You should be able to see each injector firing. It will be just like mist but check the spray pattern on each injector, and more importantly that they are all working.
If its ok put it back in. Check that plennum has no leaks becuase they can be pretty nasty.
I dont know if i would recommend this, as the fuel pressure could easily blow the injectors out, potentially spilling litres of fuel under pressure. If you leave the injectors in, and unplug the igniter, pull the cas out and spin it you should hear the injectors firing, or test them with a noid light. Are you sure all the earths are hooked back up, there are two from the loom to the inlet manifold. Also check for power between one of the injector wires on each plug and the manifold. One wire on each injector should have battery voltage, the other is a swithed earth. PS are they the same injetors that came out of the motor before the maniflod change. Could there be a possibility that the fuel lines have been swapped around on the fuel rail(seen this a few times)
Edited by Adriano
Seeing has its an r33 with side feed injectors, you should be safe to do this. The injectors are held in firmly by the base of the rail, and also by the top 2 screws above each injector. The bolts holding the rail simply hold it in against the top plennum o-rings. I would not recommend this with an rb26 but as that is likely to occur.
Edited by James_03
thanks for your replies.
the fuel feed line is coming from the fuel filter...so its the right way around.
everything has a circuit and a good earth. and yup adriano injectors are getting 1 12v current and 1 6v current.
i will check the cas, however it doesnt appear to be ignition...the injectors arent opening.
i wil have a look make sure there are no rags in there too.
and yea STOCK FPR.
thanks mate,...just bought one.
pulse is fine, ignition is fine. the fuel seems to stop at the fpr. i even chucked in my nismo adj fpr, and it only flows fuel if the screw it almost wound out, at very low psi.
now that flows enough fuel to start it...but doesnt keep running.
it is almost as if the fpr is blocked. but blew it with a compressor and it is clear, but doesnt flow..
any ideas, appears to be the fpr.
both stock and nismo dont flow enough fuel
just making 100% sure that the fuel line from the filter is going to the fuel inlet (not the line connected to the fpr) and the return line to tank is connected to fpr.... your symptoms still sound like lines are mixed up.
yea mate, no need to apologise. i dont care. speak your mind :D
yea we checked all that, even tested it without fpr on,.
fuel pumps out fine
your absolutely right uras. it is all hooked up fine :banana:
are these the same injectors you were running before plenum upgrade or upgraded injectors?
if they were ultrasonically cleaned and left to sit for a while (days-weeks before installation), the pintles tend to stick and do not open, been down this path myself a couple of times, now i don't get injectors cleaned until the day i plan to start the car
sorry to explain the basics again!
but,
1) remove both fuel hoses from the rail/reg, face both into a bucket, get mate to prime pump (ignition on) fuel should piss out for 5 secs as the pump primes, take note of what hose fuel comes out of!
2) now connect that hose that fuel comes out of onto the inlet to the rail, that is the opposite end of the fuel pressure reg.
3) now get mate to prime pump again (might take a few primes to fill rail, crank it if you prefer) does fuel come out of the fuel pressure reg exit pipe?
4a) if yes, hook the other efi hose back up (return to tank), you know for fact you have fuel.
4b) if fuel does not come out of the reg, the reg is stuck/jammed closed or rail blocked (both highly unlikely)
now for spark,
1) remove the coil pack cover, remove no 1 ignition coil (easiest) remove spark plug from engine,
2) push spark plug back into ignition coil, hold the coil pack and make sure the spark plug body is touching a good earth point on engine
3) get your mate to crank engine and check for spark jumping across the electrode tips as engine cranks.
4) once you have confirmed that, remove all 6 spark plugs and make sure they are clean, they may be fouled (look black and wet) from all the stuffing around and they will not fire. its critical they are clean, get some petrol and sand paper and compressed air, clean them good.
ok. think me and my mates found the problem. we used the noid light=working fine.
looked at spark=worked fine.
we lowered the fuel pressure to minimal...just to start it,,,and it did start.
however on the boost gauge, we werent reading any vacuum. it was on 0.
we then noticed a break in the seal of the TB.
so no vacuum would cause the fpr not to open, hence no fuel getting in with the right pressure., atleast thats what we think.
so we will fix up the TB seal later and see how we go.
thanks for the advice
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
