Guest Boxhead
i thought i would help all you guys out for ppl who get a 2 din stereo in the car, want to pull it out and put in a 1 din stereo...
the way to go for a dash insert such as the one illustrated in teh picture, is to go to your local nissan service center, and ask for the tray insert from a z32 300zx... they are the same and fit nicely.. for the r32 anyway, im asuming the r33 also has same set up...
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/
Box,
You have the same stereo as me! heh.. I have the same trouble with the thing that goes around it.. only the top of it clips on, and it occasiaonlly falls off.. but doesnt phase me that much.
hey.. anotehr thing.. whats the point of that cirle part on the LED screen on the right where it displays what station preset your listening to.. is that all it does? or does it move with the music or something?
Seems pointless to me
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-53403
  • 3 weeks later...
Guest BlackBeastR33
Hey guys,
My R33 arrived from Japan with a single DIN unit sitting loosely in the dbl DIN space... wired up but not secured to anything.
So I've ordered and received the left & right radio brackets and dash tray, but now I've no idea where to start to install them!!!
How do I remove the trim so I can get inside that space and start screwing in the brackets and screw them to the single DIN unit... what screws on the dash do I need to undo??? Which bits do I need to pull out???
We really need a tech docs section I reckon!!!
Thanks *heaps* guys,
Cheers,
Mark
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-63646
  • 4 months later...
Blackbeastr33: I just pulled my whole surround off, you need to pull the surround around your gear knob (that plastic shit) and undo the screws underneath it. then the rest of the dash is clip so just pull on it and it will come off by itself :rolleyes: You will need to undo heaps of switch wires that are connected to the whole dash shroud.
Cheers
Sumo
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-147566
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
