Guest Boxhead
i thought i would help all you guys out for ppl who get a 2 din stereo in the car, want to pull it out and put in a 1 din stereo...
the way to go for a dash insert such as the one illustrated in teh picture, is to go to your local nissan service center, and ask for the tray insert from a z32 300zx... they are the same and fit nicely.. for the r32 anyway, im asuming the r33 also has same set up...
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/
Box,
You have the same stereo as me! heh.. I have the same trouble with the thing that goes around it.. only the top of it clips on, and it occasiaonlly falls off.. but doesnt phase me that much.
hey.. anotehr thing.. whats the point of that cirle part on the LED screen on the right where it displays what station preset your listening to.. is that all it does? or does it move with the music or something?
Seems pointless to me
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-53403
  • 3 weeks later...
Guest BlackBeastR33
Hey guys,
My R33 arrived from Japan with a single DIN unit sitting loosely in the dbl DIN space... wired up but not secured to anything.
So I've ordered and received the left & right radio brackets and dash tray, but now I've no idea where to start to install them!!!
How do I remove the trim so I can get inside that space and start screwing in the brackets and screw them to the single DIN unit... what screws on the dash do I need to undo??? Which bits do I need to pull out???
We really need a tech docs section I reckon!!!
Thanks *heaps* guys,
Cheers,
Mark
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-63646
  • 4 months later...
Blackbeastr33: I just pulled my whole surround off, you need to pull the surround around your gear knob (that plastic shit) and undo the screws underneath it. then the rest of the dash is clip so just pull on it and it will come off by itself :rolleyes: You will need to undo heaps of switch wires that are connected to the whole dash shroud.
Cheers
Sumo
https://www.sau.com.au/forums/topic/2034-dash-tray-insert/#findComment-147566
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
