Ignitiondvd Hot Spots + Dyno Comp!, Friday The 1st @ R.e Customs
  • Replies 123
...wow this looks like its gonna be huge!
Will hang back at work till 730 then head down.
:sad face due to measly ~300 run in tune:
trust me, that's more than alot of cars will be making.. including mine >_<
doesn't matter if your car isn't making massive power, just come down, watch or enter the dyno runs and get some free giveaways :banana:
shaping up to be a big night!
As per the other thread I'll be down there, to find out how much awkw my car is running. The mods are well...not completely known >_<.
Hopefully I'm making some decent power.
Anybody from around Bayswater going? wanna gimme a lift? >_<
..or pick me up from a station some where?
if anyone can help out gimme a buz on 0420974417 :banana:
my comp is being repaired atm so i have no net..
Edited by Jezza-gtR
I will try and make it.. Ill see how many other boys i can get down there aswell..
As for the ignition DVD.. it struggles as far as cars go, but the owners are HILARIOUS! :D
i've only got full 3" exhaust and one of those $30 boost controller jobbies, so i ain't going to be running huge numbers... i'll just be doing it for the curiosity factor of knowing what my car is making. Never had it dyno'd before
but yeah, between here and NS.com, sounds like it's going to be packed...
how many cars could they run back-to-back in say a 4 hour period?
dont know thinking about it
as i dont have alot of cash at the mommet as im heading to qld next week to do the whole theme park shit and yeah party for a week
so im trying to save money for that
but we see how i feel i just told friend in his aristo and he may enter but we see i think about it
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
