  • Replies 40
Yer thats wat i thought
He never decibel tested it but im guessin it would be very close to the limit
He just decided he would make me lose a point and a $75 fine afta lookin at it
if you have ANY part that isn't standard on your car, then technically you need a mod plate
it might be legal (as in under 90dB) but you need an engineer to prove this
most don't bother but if you got done then unfortunately they are within their rights
So i do need a mod plate
Thats pretty shit
Well i bought the car off a fairly reputable dealership and u think that u wouldnt be able to get a roadworthy without one (Obviously some fairly easy ways around this tho)
Thx For all your help guys!
A simply rule of thumb for you;
If the car comes standard with a item and you replace it with a "better" or "different" item you do not require a mod plate.
For instance i put a high mount turbo on my r33 when i had it, and no i didnt need a modplate as he car was factory fitted with a turbo. I was simplly changing it for a "better" aftermarket item, and i still included all anti-polution items required to make it 100% legal...
So in short no you do not need a mod plate for an exhaust at all.
As for legality of the exhaust all you need to watch out for it that at the lowest point it is more than 100mm off the ground and that it is not over 90db and you'll be fine...
Yer thats exactly what i thought
But the police make the decisions and from what ive seen and heard they almost always final
Just gotta get on with life and accept the responsibilty/Bad reputation of owning a skyline
STILL WORTH IT THO!
Well my understanding was depends on which law they are reading, and thier personal interperatation of that law.
Either way the system needs sorting out so its the same for all states, with one interperatation.
That was my understanding, something like changing your exhaust falls under the "light modification" rules for queensland transport. Only the "heavy modification" like engine/transmission swaps, changes to safety features (e.g. cages) etc etc required mod plates.
Unfortunately then there's the new police rules which don't seem to coincide and leave people wondering/fined etc.
go to court.
the actual fine should read "modifying a silencing device so as to reduce it's effectivnes"
probably worth a try arguing that it's purpose is to keep the car below the set legal limit, and that it still does that so it is in fact not reducing it's effectivness.
was it a traffic cop?
better chance if it was as most magistrates don't really seem to like traffic cops.
Another way to think of it;
Ok, so a car has an OEM exhaust from new, you drive said car for 5-6 years and it starts to devolp an exhaust leak.
So you take the car to an exhaust shop and simplly say fix it, so they then find there is a rust hole in the muffler and say no worries we will put a new muffler on.
If one were to need a mod plate, technically this person above would require one too. As no exhaust shop puts in OEM parts even when simplly replacing a dodgey muffler.
Hence requiring a mod plate for an exhaust is not true, as almost every car thats more than 10 years old would have had some form of exhaust mod made, and if a car were 15+ years old the entire exhaust would have probablly been replaced at some stage.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
