R32 1993 GTST RB20 Standard Parts
Freight at cost on most parts available
OPEN TO ALL REASONABLE OFFERS
All parts from a running car. Removed as stripping the car for racing
RB20 Turbo complete with elbow $SOLD
Exhaust complete from front, dump, cat and two mufflers. 2.5" Nice and quiet for ADR approval. $200
Air-conditioner parts.
Compressor $120
Radiator $100
Pipes and canistor $200
Front brake calipers complete with pins, clips and shims. Needed to be opened with some force so may need to be re-kitted. $50
Front brake rotors. Need machining. $40
Fan shrowd for radiator. $SOLD
Side mount intercoller and some pipe. $40
Duct. Think it is for standard air box. $50
Standard air box base. No lid or filter. $25
Ignition switch. Works OK but key can be removed in all positions. Plug cut off. Key supplied. $10
HKS idle stabilizer. $30
Air fuel amplifier. $30
Stone guard. $SOLD
Bonnet catch. $20
Bonnet cable. $30
Horns. $10
Support. $15
Central locking actuators. Each $10
Space saver wheel. $80
Set of 4 standard wheels and tyres. 50% tread. $200
Spare wheel cover. $20
Boot rear interior trim. $15
Boot corner trim. $10
Carpet mat. $20
Passenger side front seat. $100
4 x retractable seat belts. Each $100 or for the set. $75
1 x seat belt catch. $20
Centre consule. $75
Gear knob. Split at the seams both sides on top. $5
Rear parcel shelf. $15
Moulded carpet. $50
Roof lining. $30
Sun visors. $15ea
Suicide handles and coat hooks. $10
Interior light. $15
Map reading light. $20
Speaker mounts for front doors. $5
Vents for climate control.
Centre. $20
Left. $10
Right. $10
Rear pillar trims. $20
Assorted bits and pieces from $5
Edited by just_racing
https://www.sau.com.au/forums/topic/203452-r32-1993-gtst-rb20-standard-parts/
do you have the rear seats?
also is the stone guards the ones under the engine?
No back seat when i got the car. Yes stone guard is from the front to under the engine.
do u have a clock spring? (thing inside steering column that make indecator stalk returning) if u do I'd like it delivered to 2250 nsw, how much?
cheers
no sorry still using it.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
