R32 1993 GTST RB20 Standard Parts
Freight at cost on most parts available
OPEN TO ALL REASONABLE OFFERS
All parts from a running car. Removed as stripping the car for racing
RB20 Turbo complete with elbow $SOLD
Exhaust complete from front, dump, cat and two mufflers. 2.5" Nice and quiet for ADR approval. $200
Air-conditioner parts.
Compressor $120
Radiator $100
Pipes and canistor $200
Front brake calipers complete with pins, clips and shims. Needed to be opened with some force so may need to be re-kitted. $50
Front brake rotors. Need machining. $40
Fan shrowd for radiator. $SOLD
Side mount intercoller and some pipe. $40
Duct. Think it is for standard air box. $50
Standard air box base. No lid or filter. $25
Ignition switch. Works OK but key can be removed in all positions. Plug cut off. Key supplied. $10
HKS idle stabilizer. $30
Air fuel amplifier. $30
Stone guard. $SOLD
Bonnet catch. $20
Bonnet cable. $30
Horns. $10
Support. $15
Central locking actuators. Each $10
Space saver wheel. $80
Set of 4 standard wheels and tyres. 50% tread. $200
Spare wheel cover. $20
Boot rear interior trim. $15
Boot corner trim. $10
Carpet mat. $20
Passenger side front seat. $100
4 x retractable seat belts. Each $100 or for the set. $75
1 x seat belt catch. $20
Centre consule. $75
Gear knob. Split at the seams both sides on top. $5
Rear parcel shelf. $15
Moulded carpet. $50
Roof lining. $30
Sun visors. $15ea
Suicide handles and coat hooks. $10
Interior light. $15
Map reading light. $20
Speaker mounts for front doors. $5
Vents for climate control.
Centre. $20
Left. $10
Right. $10
Rear pillar trims. $20
Assorted bits and pieces from $5
Edited by just_racing
https://www.sau.com.au/forums/topic/203452-r32-1993-gtst-rb20-standard-parts/
do you have the rear seats?
also is the stone guards the ones under the engine?
No back seat when i got the car. Yes stone guard is from the front to under the engine.
do u have a clock spring? (thing inside steering column that make indecator stalk returning) if u do I'd like it delivered to 2250 nsw, how much?
cheers
no sorry still using it.
