Hey guy's, im having major troubles with boost. I upgraded a bunch of stuff...
PFC
high flowed turbo
FMIC
high flow injectors
fuel pump
all the usual stuff. on the dyno when tuning it gets to 15psi then drops way down to 9psi. only got 160rwkw!!
the things we have checked...
sent turbo off to be tested, was ok (including actuator)
tried 3 different boost controlers
clamped the BOV line when on the dyno
thats all i can think of but we have been trying to work it out for a few months now. before the upgrades it was holding 12psi fine. any ideas would be muchly apriciated, thanx guys
https://www.sau.com.au/forums/topic/203471-losing-boost/
have you tried putting more preload on the wastegate actuator?
is your exhaust restricted in any way?
other things to try would be to see if you've got any leaks in your intercooler piping by hooking up a compressor to one of your vacuum lines and blocking off the intake. then just spray some soap around silicon joiners, vacuum hoses and the plenum to runner gasket and see if anything bubbles up.
https://www.sau.com.au/forums/topic/203471-losing-boost/#findComment-3608117
we took the cat off and drove it so only the dump and front pipe were conected (loud as f**k and run shit) but it still did it. I did put more preload on the actuator. the air compressor cooler piping trick was what i was goona try next, so it looks like thats what i need to do. thanx for the help mate, any other thoughts are VERY welcome as im getting really over this, just spent 5k on my car and its no better then it was lol!
https://www.sau.com.au/forums/topic/203471-losing-boost/#findComment-3609279
the standard dump pipe starts to get restrictive after around 14psi ive noticed (its very narrow around the wastegate exhaust port) so it wont really matter if you ripped the cat back off. do you have an aftermarket exhaust or is it still standard?
https://www.sau.com.au/forums/topic/203471-losing-boost/#findComment-3609362
yeah its got a high flow dump/front pipe in one, into a 3.5 inch system.
https://www.sau.com.au/forums/topic/203471-losing-boost/#findComment-3610077
hear any strange noises?
there is another thread in this section and that guy is having leaking problems.
nah i cant hear it leaking or anything. i just tried the compresor trick and it just went straight through so i didnt block somthing off that i should have. the line into the actuator held 60psi but all the other lines held 0psi. :)
https://www.sau.com.au/forums/topic/203471-losing-boost/#findComment-3612797
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
