Cost will be $50 members and $55 non members.
There will be winners crowned for each category of:
Highest power R31
Stock Turbo R32 GTST
Aftermarket Turbo R32 GTST
Stock Turbo R32 GTR
Aftermarket Turbo R32 GTR
Stock Turbo R33 GTST
Aftermarket Turbo R33 GTST
Stock Turbo R33 GTR
Aftermarket Turbo R33 GTR
Stock Turbo R34 GTT
Aftermarket Turbo R34 GTT
Stock Turbo R34 GTR
Aftermarket Turbo R34 GTR
Highest power N/A
No prizes this time as it's just a friendly competition and to see how your car is going.
Dyno is a Dyno Dynamics all wheel drive dyno so GTR's will have no problems.
10am til 4pm or later if there are still cars to go on and if Hills agree on the day. I will be there a bit before but first car goes on at 10am.
This is usually a big one for us and this year for the first time we will be doing an early and a late year dyno day. The next one will be at UAS most likely. I will be taking money and names on the day so that everyone goes on the dyno in order of arrival. Bring your membership cards club members. We will have membership forms available on the day for those who want to join.
Hills Motorsport is located at Unit D6, 2A Victoria Ave, Castle Hill. It's the complex on the corner of Victoria Avenue and Windsor Road opposite a big Holden dealership (same complex as UAS used to be in) and it's up the back on the left.
Hills are putting on a free bbq for us and supplying some drinks. There is a drink machine if they run out. They should have some chairs in the shade and will have a screen for us to gawk at.
Post your interest.
DON'T FORGET, IT'S ON THE 1ST OF MARCH
  • Replies 327
Posted Images
Interested expressed. :)
(question - does a "hi-flowed stock turbo" come under standard turbo or aftermarket?)
aftermarket as it's not in it's stock standard state.
that's what I was told at UAS Dyno day last year anyway..
Wow, that caused some fun last time around!
Dont start something you can finish peasant
You going queen jerk?
Tell king jerk to come
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
