Oops yeah, sorry there was a magic run from a boat that no one saw :bunny:
When you left it was, but then Evan pulled a 181.1 on a peak of 20psi towards the end of the day
Thanks For the day is was good and fun was had by all i think.
2 of my boys took out some classes me in stock R32 GTS-t and Babak in Modified R32 GTS-t and Most Power :D
on 20 Psi the car isnt like any normal R32 the torque jumps heaps nearly 2000 Newtons.
if only i had a Computer and a electronic boost controller we could realy see what the stockie can do :P
-Evan
PS Steve-o Wheres my prize hehehe jks.. :D
  • Replies 327
Posted Images
-Evan
how many scoobie snacks to make 2000nm of torque?
Just like to say Thanks to Hills motorsports for an excellent day.
Cheers to the girls for the bbq.. and thanks to everyone who turned up. It was an excellent day I wish I could have stayed longer but I had to go.
Good to see a variety of cars there and nice to know the povo ute makes 116.4kw's woooo!
OK full results were:
Name Rego Class Result
Ian Burgess BEP-88X Stagea 121.9
Beau Franke BDU-98W 33 GTR 233.7
Corrine Murray WWO-55t6 Commonwhore vs 116.4
Sean Lloyd ANS-71G 32 GTR 322.2
Ben Martin TRB-26T 32 GTR 212.3
Josh Kavchev BCF-52W 180sx 162.6
Levi Baker TNY-111 R31 101.3
Jamie Row ROW-E88 Commonwhore VZ 150.5
Steve WRX-08U WRX 192.6
David Hellerman AYY-56C 32 GTR 311.3
Burnsie AF-80-EE 32 GTS-T 242.5
Josh Johnston HA-82-BU Commonwhore VX 301.1
Adam Parsons NAT-95H 33 GTS-T 181.1
Brian Cherry AO-86-GQ 33 GTS-T 217.9
David Prince AD-77-XE 33 GTS-T 162.0
Matt Everingham BEW-05S Evo 7 173.2
bard Warner FEAR 32 GTR 282.2
Mitch King MRM00E 33 GTS-T 201.9
Courtney Madgar GRR-32R 32 GTS-T 165.4
Nick Tuyau STR-86T Stagea 142.7
Sam Grimston YMP-732 33 GTS-T 173.6
Bassam AL-59-PZ 32 GTS-T 169.8
Liz Corr LI-22-EH 180sx 177.3
Ben Lucas AE-71-VE 34 GTT 336.9
Damien UKF-538 AMG C32 207.4
John Atzemidakis GR-34-TT 34 GTT 169.9
Charles Kwawhy WPN-33R 33 GTS-T 264.3
Evan King STG-23R 32 GTS-T 181.8
Phillip Truong AXL-89W 33 GTS-T 200.6
Lawrence Tang MYH-22A Prelude 107.7
Leon Wrong BED-32L 34 GTR 210.3
Matt Wheatley VH-34-TS Evo 6 163.8
Steve Hill DRD-00F 33 GTS-T 178.0
Kristof Kazmer KK-535 ? 254.0
Ryan Watson AUM-03K 33 GTS-T 174.1
Sheng YF-34-RR 34 GTT 197.3
Daniel Vaughan IMEASY 33 GTS-T 175.6
Babak RB GUN 32 GTS-T 365.9
I don't have the details on class (stock v aftermarket turbo) so I can't confirm that.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
