Great turn out today, over 40 cars in 6 hours made it onto the dyno. Well done to Mark and the team those guys were flat out all day. And great bbq too thanks ladies.
Well done everybody :P
Sadly my taxi couldn't make the dyno, even though I changed the fule pump and fixed the boost controller (OK bard did all the work and I watched :) thanks mate) it was still pinging over 5k - need to get the PFC in and see if it is just a tune or something else.
Pezhead, your 4wd is rooted - do you have a warning light, or does it just not work?
  • Replies 327
Posted Images
Oh, and watching Josh get 301rwkw in his cammed VX SS makes me want an LS1 again....
Yeah 301's ok......the winner was 365 :)
Hey folks great to see such a good turn out. For those that wondered why mine came back off the rollers before a run my front clutch pack is stuffed so I didn't want to do it any more damage. Geez out comes the VISA card again!
At least this confirmed it before I did any more damage out at power cruise. I hate it when my toy is broken :P
Glad to see so many tough machines today.
Very nice to see your car, as i said before, its just mint clean!
Shame about the clutch pack but thats cars :)
How was powercruise?
Yeah 301's ok......the winner was 365 :P
OoOO What made 365kw Steveo?? Was that the highest reading of the day?
RB GUN was the winner, with 365rwkw, packed in an r32 gtst
Although GTRsean did very well with 322 ALL wheel kw, shame we didnt get him to pop the fuse and get an rwd mode run in
I think you should check your sheet again.. someone hit a lot higher than that :P
lol true apparently there was a 600kw boat
Oops yeah, sorry there was a magic run from a boat that no one saw :)
aye n1 gtr........ was my 169.2rwkw the best for standard turbo @ 10psi for r32 gt-st???
When you left it was, but then Evan pulled a 181.1 on a peak of 20psi towards the end of the day
Oops yeah, sorry there was a magic run from a boat that no one saw :P
wow......that was brave of him
Thats what i thought but it was only a peak of 20, most was around 15psi i think (saw a lot of readouts today, pretty sure the one im thinking of was his)
Good to meet a few ppl today face to face.. chris, burnsie etc.. had a really good day guys and
glad i made it on the rollers :P here my in car vid..
*ps* its not the tool, is the user :)
Liz owes me 20c :)
you owes us an apologize for lying :)
my pic for the day.
haha.. my quote of the day ;)
thaTS MASSIVE WAS THAT STANDARD TURBO??? when are official numbers being posted??
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
