Hi all,
I am unable to upload pics up.. If your interested PM me your email and I will send you the pics :P
I have for sale:
2 Pairs of stock GTR exhaust manifolds $70 per pair
Pair of stock GTR dump pipes with heat shields $30 for the pair
Pair of stock GTR cam gears $10 for the pair
Pair of old school HKS BOV for a GTR with a mounting bracket $80
Pair of stock R32 GTR turbos with stock actuators$280
Pair of stock R32 GTR Camshafts $140
Stock RB26 oil and water lines $120
Stock RB26 set of lifters/buckets $120
Stock R32 GTR air box components $20
Stock RB26 twin turbo pipes (yellow minus badge) $120
Stock R32 GTR front pipes with stock cat $30
Stock R33 GTST stock air box with snorkle including Apexi panel filter $160
Stock R33 GTST steering wheel non air bag in moderate to good condtion $20
Stock R33 GTST turbo back exhaust $130
Stock R33 GTST heat shield $5
Stock R33 GTST front and rear swaybars make an offer
R33 GTST Hawk brake pads front (HB179F 630) and rear (HB178F 564) make an offer..
R33 GTST HICAS unit make an offer
R33 GTST O2 sensor bracket $5
R32/33 GTR valley cover badge in good contition $50
Motul RBF 600 brake fluid $20
Blitz Racing black faced mechanical boost guage 60mm 1.5bar $120
Nardi horn button $40
Nardi boss kit for Datsun $20
4 Pioneer speaker covers for 6.5' speaker $20
R33 GTST/GTR air vents (silver) $10
R33 GTST/GTR rear parcel tray vent $10
Arial antenna for R33 SOLD
Stock R33 GTST rims in good condition with tyres SOLD
Delivery will be at buyers cost..
https://www.sau.com.au/forums/topic/203577-various-gtr-gtst-parts/
Further and most likely final price drop.. all PM's will be replied to tomorrow :P
First in with the money here on in gets the goods.. too many people have asked for items to be held then pulled out leaving genuine buyers and myself in limbo ;)
As stated before, make an offer if you think the price isnt fair.. I need these gone soon otherwise most of these parts are going to the tip for the monthly clean up :)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
