Make: 1994 series one
Model: gtst
Milage: 126000
Transmission: manual
Colour: red
Complied? yer
RWC supplied? no
Currently registered? yes
Price: 10000
Contact: pm or here
Comments / Modifications:3 inch exhaust with zetti cannon. cd player. 400r bodykit. good interior. lowered suspension. front facing standard plenum
Images:
Reduced: 66% of original size [ 909 x 682 ] - Click to view full image
the 400r front bar was broken from driveways so i replaced it with a standard bumper but its white and car is red. bonnet flew up so has small damage on the roof and has black painted bonnet on it. il get more pics later
  • 4 weeks later...
i know GTST was after a skyline under 10k, you could fit the profile..
expect i do have a few queries.
No roadworthy
No pictures
The link you sent amy was to a stupidly long post where people are asking for pictures, then eventually you send an engine bay pic from carsales.
I did a carsales search for 1993-1994 skylines with 100k+ on the clock and could not find yours.
is this is hope-that-people-buy-it-without-seeing-pics-and-no-roadworthy kinda bag?
I hear being above board is better then not telling people why it wont pass roadworthy etc. Im sure its not your fixed bonnet or the smashed front lip.
only saying this as i just sold mine and it was hard enough being straight with everyone. amazing how hard it is to sell the ol r33's. I had to sell mine way below market value and mine was in bloody good nic. 2 mechanics went over it and only said brake pads & a powersteering pipe would need replacing.
No roadworthy
No pictures
theres pics in the link on 2nd page i think it is. doesnt take too long to scroll down until you see the pics. the engine bay pic is from when i bought the car but i can assure you its still in there.
the brakes and steering and suspension and lights work. itl pass roadworthy depending on where you go. i dont have time to get one.
car for sale 8000
  • 4 weeks later...
i went to pick up the new bonnet for it the other day but it didnt fit in the 4b so il be back with a trailer in about 2 days. il get the bonnet painted gloss black and can have the bumper painted same colour as car.
buy it
  • 1 month later...
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
