in my 32 gtr
when i hit boost say 3000 - 3500 or so rpm the car feels like it goes slower
revs jump up but you actually feel like you lose power!
im thinking it may be a clutch slipping
does anyone have any ideas or had the same problem
...does anyone have any ideas or had the same problem
Sure, if your driving, and hit peak tourqe and the revs flare, but you aren't accelerating anymore (or minimally) then your clutch is prolly slipping. Does it re-grip later in the revs?
Get a mate to drive behind you, he should be able to smell the acrid smoke.
clutch slip for sure dude!
find level ground, apply hand brake, push clutch in and select 4th gear, let clutch out slowly.....if it stalls your clutch will last a little longer if your cruise round off boost, if it doesnt stall, she's a rooted!
When you replace the clutch, it would be worth getting a new rear main seal and your flywheel machined. The flywheel machining is critical as if you dont get it machined, you can get severe clutch shudder when taking off with the new clutch is installed.
^^^ No offence, but f_ck a flywheel skim, assuming your on a mission to mod (its a GTR) grab a twinplate and lightened f.wheel combo now, otherwise you'll just be trying to hock your newish OEM clutch and re-surfaced f.wheel in the for sale section down the road.
Edited by GeeTR
  • 3 weeks later...
new exceedy clutch in and all better !!!
just had the fly machined
did the timing belt and all that at same time
so lets say i could just about add 2 g to my gtr purchase price
but now everything is freshened up :)
which one did u end up getting?? price for clutch and installation - $2G?
Na, he did the clutch and a 100k major service on the car at the same time, belts, fluids, water pump, filters etc
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
