hey everyone, last saturday night i broke a rear axle, ive had a search and cant find anything
just wondering if anyone has done a tutorial on how to replace one, ive got the centre nut off, just not sure where to go from there.
if anyone could share their experiences it would be much appreciated
thanx
https://www.sau.com.au/forums/topic/203614-replacing-rear-half-shaft/
You've done the hard part now.
All thats left are the 5 bolts at the diff and you pop the drive shaft out.
Depending on which side of the car it is you have to drop the exhaust to give yourself a bit of room.
You might have to tap the driveshaft out as the splines tend to bind up.
ah cool thanx, yeh was just wondering how to get it out of the hub, wasn't sure if it was bolted in or not. tried pushing it out last night, didn't work lol. ill get a rubber mallet or something. do you have to undo anything else on the suspension? or just drop the exhaust and put the new one in?
It's only held in with the 36mm nut at the hub end and the bolts at the diff. If it doesn't slip out just get a bigger hammer seeing as it's already buggered.
You don't even need to remove the exhaust if you have the room to get at the nuts and bolts, but i usually just drop it off the hangers to make life easier. There's plenty of room to get the shafts in and out either way.
thanx, but the problem i have is getting the axle up over the subframe and into the spline, any tips on how to get it in without undoing any suspension arms?
im really stuck, and need my car to get to work, i miss driving it lol
hey, i just want to thank everyone for their help, so thanx
ive taken my car to the mechanic as im unable to get the hub out myself, so should be on the road sometime today, yay
thanx again
