Sold My Skyline Today
abcent
 Share
Well it finally happened, today someone drove away in my 33 gts-t, it'll be put on a transport truck & sent to Darwin on Thursday, so at least I wont see it cruising around.
now what to do? buy a GTR? an EVO 8 MR? a BMW M3.......or do the responsable thing and buy a house? cant decide? nothing will be happeneing for at least 6 months anyway, so time will tell......
hey berin - congrats and well done, nothing is worse than selling your pride and joy
all the best in the future - id say buy a house - you can play cars later when you get settled into the house
Great new Berin; happy for ya mate!
As much as i may sound like a hypocrite i would suggest to buy a house and stop wasting money with renting a house. Do it soon as house prices are starting to sky-rocket again.
Berin, good to see it go, but not at the same time! I say buy a shitter and drop a 13b into it. Old Ae71 corollas go for dirt cheap, solid mount the rota, welded diff, chopped springs. Perfect combo. Go terrorize the dr1ft3r5 in your area.....
Rent mate
And buy a GTR...and make it a 34...
thanks for the kind words guys! I'm leaning more towards a house at the moment, I have a KTM for weekend fun to tide me over for a bit. Might even get some motard wheels for it so I can come on cruises still :( lol
Ride the KTM and buy a house. Motard wheels and the setup costs a bit.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
