Just got a KEAS shift kit installed in my R33 auto. Gear changes are lightning fast and it cherp's second no worries. Shifting from 1st to 2nd can be harsh at low speed but overall impressive. What i want to know is, are these shift kits safe or will my auto box terminate in the near future? I could not imagine a transmission company like KEAS making these shifters for auto transmissions if they were a ticking time bomb.
Overall very impressive.
https://www.sau.com.au/forums/topic/203634-shift-kit-in-4-speed-auto-r33/
  • 4 weeks later...
as i understand the kits reduces flaring of gears, thus reducing wear
i can see that it might increase temperatures though, so have you considered a trans cooler?
i ran a shift kit and trans cooelr on my R32GTSt auto for about 1.5years and it ws perfectly fine :(
$385 for the unit. Takes about 2 hr to do. Box has lasted so far 3 weeks! still going strong. I think i will get myself a big trans cooler, they are cheep as.
Any one know a good size cooler to get?
Pipe size? and where is the best place to install it?
i mounted mine just behind the front bar infront of the drivers side front wheel.
get as big as you can fit.i got a V8 size one.but there is bigger still.
Just get the same size line as the outlets on the cooler,it will say it on the box.
  • 1 month later...
hey man
my name is nathan. i am planning of building a burnout car, using a vl commodore body and bolting a rb25det engine into it. i dont want to run a manual bearbox, as i was thinkin about using a r33 gts-t auto trans box, torque converter and flexplate. what are the auto trans boxes like? do you know of anybody that does tricking up of the autotrans boxes so they can take a bit of a thrashing for doing burnouts? please let me know dude. very much appreciated. cheers
nathan.
far as i know, less heat is generated from autos with shift kits due to less slippage on clutches in them, therefore less heat. its the diff you have to worry about. all the hard shifting is not good for them.
hey everyone do you know if these shift kits are available in the US or if anyone of the shops over there would be willing to ship one to teh states if so email me [email protected] thanks a million im not sure but i think i have a 4 speed auto early series 2 like a 95 ecr33 with series 2 motor
ive had my shift kit from mike at mv automatics for like 9months maybe a year and it has been fine i always check fluid in auto to see if it was burning but its still a nice red color
spun me out the first time i got back in the car from mike take off and changes gear alot more solid fills good when you give a little test and chirps my 19 no worries but be careful in the wet he will say i can vouch for that.
get it and see what a real auto feels like. :P
hasnt screwed my box or diff yet
  • 3 years later...
Mike ships all over the world:
MV Automatics
1 Stirling Rd, Blackwood, SA 5051
p: (08) 83700430
Hey im looking at getting a shift kit around the ipswich brisbane toowoomba area, and whats involved in installing these kits or alternativly what businesses would install them and does anyone have a rough estimate on price? (wow thats alot of questions :P)
  • 5 months later...
i have one of these kits, gearbox lasted me about 3 years, now the clutches in the 3/4 drum are gone and up for over 2k worth of repairs. so it does take its toll on the car, it was making 225rwkw, and rebuilt it and made 255rwkw and started to slip on the dyno.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
