Hi Guys
I have the following i need to sell... free up space.
Volks TE37 white - rim only second hand
18 x 9.5 + 35
18x 8.5 +30
$2200 - --- SOLD SOLD SOLD
Greddy R34 Coilovers brand new
$1800 - brand new in box
New price 1700 -lowest ever .... brand new!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apexi Power FC R34 brand new with controller $1600
NEW PRICE $1500
PM me
I'm located on eastern Adelaide
Edited by blues15
https://www.sau.com.au/forums/topic/203661-greddy-apexi/
  • 1 month later...
