So what would need to be done to build an RB30E block to take an RB25DET Neo head?
The car inquestion is a 5spd stagea RB25DET Neo, running perfectly fine, and looking to rebuild it, seeing as how RB30 blocks arent hard to come buy i figure i'l do it properly and start from the bottom up.
The idea im hoping for is to drive the car around as is, while building up the 30 bottom end. Then, once its built, basically remove the manifolds from the Neo in the car, pull the engine out sans gearbox, remove the 25 head, mate it to the 30 block, change to a stainless turbo manifold while its out, put it back in and tune it via R33GTsT Power FC.
Basically, id like to build it so no modifications need to be done to the head in order to mate them together. Build the bottom end to suit the top. What should be my reccommended shopping lis, from those who have done it?
Is this feasible? The stock Neo runs about 190-200kW? Im aiming to end up with about 350+ from this combo, using a larger turbo, injectors, pump, regulator, cams, and any other supporting mods i may need.
I have read through a few pages of dyno results from hybrid engines, as well as the 300 page thread that started of about pistons.
refer to the RB30 conversion thread; has all the answers you need ;)
Having said that, you'll need to marry the gtr style sump to the rb30 block.
It may be easier to buy a blown rb26 and build that up slowly.
As mentioned, i read through a lot of it and its hard to get a solid list from SIX THOUSAND POSTS due to its just a whole lot of different peoples suggestions and parts of their combos. Cant just take a bit from one engine and a bit from another, can i. Plus, its 6000 posts, did i mention that?
Im after info from those who have done the conversion, from start to finish. Otherwise it gets a bit jumbled using different bits from different peoples opinions, and things dont match up very well when you do that.
Yeah, there is a "in thread" search button.
Have a crack at using that.
Also the 3ltr for a GTR applies to you (except the head, thats covered in the R33/3ltr thread)
http://www.skylinesaustralia.com/forums/Rb...on-t106224.html
So have a read of that also.
Everything you've asked i know is covered in the two threads as ive read it all ;)
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
