Well well well- as you would all be aware i never did get my Do Luck kit from "Supernautics" alias Aero nautics and or any other trading name these scum bags in Beverly Hills - (Mr Tri Tran - ANZ Bank) NSW that ripped me for $1400 . Nor did other people in the states and UK. BEWARE!!
SSOOOOOOOOO i still need at least a front bar in this particular style . there was a chap in QLD i thisnk that was doing F glass ones for some time on E bay - any one know where i can get for my drag project please.?
Thanks
https://www.sau.com.au/forums/topic/203699-do-luck-kit/
Thanks
:blink:
No one ?
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3623778
Thanks
not the best kit for a drag car. Heat treatments style is the way to go, nice rounded front end side skirts removed and rear bar trimmed to boot level. Do-luck is too square and will produce more aerodynamic drag than a std body GTR.
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3623810
Good input - thats the sort of coments and feed back i need , - is Heat treatments a custom front bar?
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3623986
The Heat Treatments front bar was designed by an ex-formula 1 aero designer so has had one of the worlds top guys to design it. it looks like this (note the side skirts have been removed and the design of the rear wing)
http://images.golivewire.com/ib/92106_t.jpg
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3627969
dmd / monkey warehouse in qld do them... they've done all my cars awsome quality and really strong give them a call.. they do ship interstate and have a very well known name and very good reputation so no chance of getting ripped off plus if you have any drama's let me know as i'm mates with the two owners
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3627997
Have contacted them already with a pick of the bar but have heard nothing back? Shame because i need as soon as possible as spray painting is happening soon. Can you touch base with them for me at all?
thanks
https://www.sau.com.au/forums/topic/203699-do-luck-kit/#findComment-3628403
  • 9 months later...
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
