Install looked tidy. Power number was very good if it was running something like a GT35 (I read 363kW) and should move that lardy Soarer pretty well when the revs are up. If it was one of those T88 units, at that power level it's seriously under employed.
I don't know if it was the scaling of the dyno graph, but it looked to have a fairly late/steep rise in the torque curve which then did not hold for long before it ran out of rpm. I wonder how stock the internals are, and how much $$ was required for the external bolt ons? There should be a reasonable supply of off the shelf speed gear available ex-US.
Edited by Dale FZ1
a t88 on stock internals.... why?
Why not? stock internals are good enough for the power he is making, which is well tried and tested in America with the 1uzfe. I assume, the owner has future plans for the car, hence the t88 now - Thus save on changing it over when a motor is "built" later on.
yeah... i kinda didn't really think of that :banana:
Toyota aren't the only Japanese manufacturer of a well engineered V8.
Soarer reminds me of an old Jag - big on the outside, small on the inside. Goes well in a gentlemen's express kind of way. Not for me, but good to see someone having a play with them.
JAgs.... dont get me started :banana: damn multicam corroded mofo's :D
GK on that thing should be good for over 1000hp easy, we supplied a GK on a std (std cams and int) 2jz (595FWKW) and it was safe as houses, ps we did it as per customers wish not cause it was a good setup :D car now has full top end build and is pushing another 200-odd more.
GK FTW :(
Check the link for some good detailed pics of a VH41/45 bottom end.
http://forums.nicoclub.com/zerothread/288890
Other than for the John Holmes award (Longest Schlong) I don't see the point of fitting them up with those massive snails. With the capacity advantage in either the 1UZ or VH45 - and some intelligent turbo matching - they would pull like a locomotive. Awesome road car. A bit like the kit that's available for the Gen 3 Commode.
I'm not sure why you think that sort of power is low. The stock cams in a 1uz are only about 220deg and 7.7mm of lift.
the stock rev limiter is 6500rpm.
The set has been built to max out the GK with a built motor.The 1uz don't have super strong rods like a 2jz, so you can't get thenm too much power.
As for tlag once you take your foot off the clutch the boost starts climbing. no lag as such.
Nobody said it's low. 360 odd rwkW is plenty.
It was more the case that the turbo's potential is not really being tapped. Fair enough for a built engine to come into the equation later on.
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
