Hi,
When I take off from a stationary position, or if I am rolling quite slowly (eg, slowing down for a right hand turn to the point of almost stopping, then taking off in first), my Stagea makes a single "click" noise, which sounds like it is coming from the front right. It's not particularly loud and only really does it the once until i slow down again and take off again.
Has anyone had this before? I am thinking CV joint? ...Keeping in mind I don't have a clue about Nissans.. :laughing-smiley-014:
https://www.sau.com.au/forums/topic/203711-clicking-noise/
I get a click similar that
only on low speed take off
single click sound from front right (sort of under my drivers seat)
seems to me to be from the auto box, only ever noticed it since the MV Auto shift kit was put into the 'tranny
https://www.sau.com.au/forums/topic/203711-clicking-noise/#findComment-3612181
  • 3 weeks later...
I have what I believe is the same problem, but only occasionally. I have had the car checked over thoroughly at least 3 times since it first started happening, and the only thing we found was dry bushes. Given that the sound happens so rarely, I'm not sure if that was it, but I don't remember hearing it since....
https://www.sau.com.au/forums/topic/203711-clicking-noise/#findComment-3653002
Is there a way to tell if a CV joint is stuffed?
After closer inspection (driving along with my head out the window), I've found that it makes the clicking noise whenever I accelerate.
Eg if I slow down then accelerate it will click..
Could be you have arthritis in your right foot :thumbsup:
https://www.sau.com.au/forums/topic/203711-clicking-noise/#findComment-3653072
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
