hi
just helping a mate out,
his found a skyline for sale but is uncomplied and unregistered, the owner says he has import and compliance docs, the car has been like this for 2 years in aus, hasnt been in an accident, and is relatively stock bar some rims, turbo timer, blow off valves (all easy to remove and replace with originals), he questioned him about the period of time its been sitting here and the owner said the compliance has been extended.....
does all this sound right? could it be complied? in nsw ? (car is in nsw aswel)
any info would be good
cheers
https://www.sau.com.au/forums/topic/203717-uncomplied-skyline-in-aus/
nah it wasnt imported as a "track car only"
i dont know much about these importing/compliane things but track only cars dont need compliance right?
his got the paperwork for this and import docs.....main thing that worrys him is the amount of time its been sitting here in aus....
thanks again
You can extend the time period for compliance every 12 months if it hasn't been done yet. If this guy says that's what he did, then he sounds like he knows what he's talking about. Ask him who the compliance guy is (find the name on the import approval) and go to the DOTARS website and look up his telephone number. Call him, and if the compliance guy says he won't comply the car for one reason or another (i.e. aftermarket intercooler, accident car, etc.), than you should probably steer clear of this car.
cheers,
david @ carizma
question you should be asking is why has this car been sitting for 2 yrs and not complied...do not under any circumstances part with any $$ until it is complied and registered...or you might end up with a whole heap of useless metal. Personally I wouldn't touch it with a ten foot pole as a lot can go wrong even with a car thats been sitting for 2 yrs. Plenty of other fish in the sea.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
