Hi SAU brethren
I feel it's time for a new battery as i just threw a crappy one in for RWC and i've been told about general benefits for the ignition system of having a real good battery, that and it will go flat after about 1.5 days of the car being armed (another issue altogether)
So... what brands should i be looking at? Car is a SI R34 GT-T.
I've seen 'dry cell' being thrown around a bit?
What CCA rating "at least" should i get?
What am i looking at paying for a real decent battery?
And yeah... whatever else i should know about getting a good battery :worship:
cheers,
daniel
cheers,
daniel
Hey,
I bought myself one from this old groupbuy:
http://www.skylinesaustralia.com/forums/Se...ies-t62252.html
Works great in the GTR, never had a problem with it.
It has some info on what kind of battery it is there...
Regards
Gareth
cheers mate, thanks for the link
seems like a nice chunky battery, will def look into it :)
anyone else have any opinions on what battery to get? (don't have a full-on stereo setup, so prob don't need anything massive)
If its the S2 r33 with the battery in the boot. To keep it in RWC or Safety Certified you need a dry cell battery or a wet one with an external vent (run hose/vent through hole in boot pan)
Ill check mine out mate, its been a dream.
Small and compact, starts my R34 easy and i tested it pretty well one day (accidently)...
i left my lights on ( H*I*Ds) for a good hour at least. Now they zap a fair bit of power and i was pretty worried, but sure enough, cranked over straight away.
Ill find out the brand and see what CCA it has (Y)
Hey, what brand and CCA rating is your battery?
I too am looking for a new battery for my R34. I'm looking for a fairly top of the range battery that will be able to handle my alarm and sound system. Cost is not an issue, I just want something that is high capacity and will be able to handle music being played while the car is off and not go flat.
I have read the group buy link (yes all 12 pages) and it seems to me that a dry cell battery is the way to go. However I want to mount mine in the bonnet and not in the boot as has been suggested. Optima seems to be the best brand to get (although these are deep cycle which is prob not what i want?).
Does everyone agree? Also, If I go for Optima should I get yellow or red top?
Can anyone recommend a brand and model that will be suitable for what I want?
I just bought (literally about an hour ago) a new D31 Optima yellow top... retail around half a grand... I'm going to have a bit of difficulty fitting it in the boot to be honest... I'm going to have to move the fuse box over, may have to make up some mounting points... I dunno... and it's pretty damn tall too...
Info on it can be found here
http://www.optimabatteries.com.au/Content/...D31A_082104.pdf
But I don't think that is for everyone, an optima of suitable size will do what you need, I just happened to need something rediculous... like the rest of my car :(
This may be a noob question, but why do most people opt to install the battery in the boot instead of in the bonnet where it belongs? Is it only because the after-market battery is simply too big to fit in the bonnet where the old battery was, or is it for another reason?
I think in the S2 R33's +onwards the stock oem location is in the boot. Usually to shift weight to the rear, make room for intake piping, bigger/forward facing plenums etc. Also makes amp wiring a little easier
Only 32s and before had them in the bonnet... all 33s and 34s to my knowledge have them in the boot...
Well I have a '98 model R34 GTT which I imported myself from Japan and it came with the battery in the bonnet. Now I'm curious as to whether this is standard for my model or if the previous Japanese owner moved the battery from the boot to the bonnet. Can anyone confirm where the factory battery was placed for my model skyline?
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
