Ok as the title suggested, I was installing some new interior ceiling light bulbs
the driver's side was a bit tight so I used a lil more force with the bulb
then it hit something and flipped out, after that all the interior lights including boot are not working.
So I'm wondering where do I go about fixing the connection?
Thanks
With a new fuse that you no doubt blew?
on Holdens it's in the kick panel (don't ask how I know that) and I think it's the same for good cars :wave:
location, location, location
Well if you don't know where your fuses are, hand your damn keys in!
There's a box in the engine bay on the intake side near the plenum, there is one above your right knee as you sit in the drivers seat, and there is a box next to the battery in the boot...
Try the one near the drivers seat first... if you've never opened that, it has spare fuses and fuse pliers :wave:
As doof said check fuses..
The one for the interial lights is located in the drivers side kick panel. ie. Under the steering wheel, there is a pull out thingy which exposes all the fuses. See diagram below for fuse meaning:
http://paulr33.skylinesaustralia.com/diagr...33-fusebox.html
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
