  • Replies 48
i see the cover for the engine bay fuse box - what about the base section ?
dont need the wiring, just the part that mounts to the chassis
Pm sent
Front left inner guard?
Sorry mate it's sold already
can i get the short shifter?
i'd like to keep it complete with the gearbox sorry mate
carbon canistor please ??
Pm sent
pm sent
Pm replied
Ill take the strut brace and also the rear passenger side taillight if in really good cond and will fit a series II.
PM sent
pm sent
Pm replied
wot colour is the bonnet?
thanks
Bonnet is black in colour, series 1 style
Depending on what area of sydney you are, I might take the white dash cluster...
Lemme know :)
Pm sent
https://www.sau.com.au/forums/topic/203925-soooold/#findComment-3617725
pics of bonnet (especailly area with dent) and also interested in cluster if it's going for the right price, feel free to PM if these parts will fit a series 1 gtst, cheers
No worries, i'll get some photos of it over the weekend
All other pms should be replied! if i missed you pls send another
cheers
https://www.sau.com.au/forums/topic/203925-soooold/#findComment-3618535
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
