  • Replies 48
i see the cover for the engine bay fuse box - what about the base section ?
dont need the wiring, just the part that mounts to the chassis
Pm sent
Front left inner guard?
Sorry mate it's sold already
can i get the short shifter?
i'd like to keep it complete with the gearbox sorry mate
carbon canistor please ??
Pm sent
pm sent
Pm replied
Ill take the strut brace and also the rear passenger side taillight if in really good cond and will fit a series II.
PM sent
pm sent
Pm replied
wot colour is the bonnet?
thanks
Bonnet is black in colour, series 1 style
Depending on what area of sydney you are, I might take the white dash cluster...
Lemme know :)
Pm sent
https://www.sau.com.au/forums/topic/203925-soooold/#findComment-3617725
pics of bonnet (especailly area with dent) and also interested in cluster if it's going for the right price, feel free to PM if these parts will fit a series 1 gtst, cheers
No worries, i'll get some photos of it over the weekend
All other pms should be replied! if i missed you pls send another
cheers
https://www.sau.com.au/forums/topic/203925-soooold/#findComment-3618535
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
