gees if you went too all that trouble to rebuild your motor with forged pistions why did you not just add stonger rods it would have cost the same in labour and then you could have forgot about it and it would be good for 370kw or 500hp.
I would hate to guess, so depending on variables, generally speaking it should be fine, but if its a 32gtr replacing old items with new makes sense. I take it you got upgrade turbos to handle 300kw? And seriously think of getting a N1 oil pump at this powerlevel for all day every day.
yeh they have ARP rod bolts.....I bought the car with the motor rebuilt if I did it I would have put steel rods in it, Also has an N1 oil pump and GT2860R turbos has all other components and support mods to handle 300kw just wanted to make sure the rods will be alright cause my mechanic was a bit sceptial bout it.
thanks for the info guys, also another quick question would the stock AFM's be ok for 300kw? Ive been told a cheap way around it is to you 2 rb25det ones??? Also I know this topic may have been covered aswell with a good pump and reg would the stock GTR injectors handle 300kw? I have a set of 660 nismos but im sure the $750 could be spent elsewhere if they went necassary
i wouldnt push my luck with the injectors and fuel pump when asking for 300..just generally not a smart move.
leave your AFM's as stock RB26DETT ones they will handle that fine (saving of about $600 from Z32's)
As it says guys I have had my motor rebuilt with forgies but it still has the standard rods they have just been shot peened and crack tested or something would they hand 300kw all day everyday? cheers
no problems.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
