and the story goes on..
Everytime the boost gets raised to 10psi or above the car starts missing at around 4000rpm.
I've got everything I need & more to get it running at 12psi which is all I want from it.
FMIC, full 3" exhaust, 040 fuel pump, SAFC II, SITC & AVCR controlling the boost.
The plugs have been changed and gapped down to .8
When I got the full exhaust on it would boost up to 10psi and everything ran fine..but ever since the AVCR has been installed there's been nothing but troubles.
and it has also developed a miss at idle...(which the plugs didn't fix)
I suggested coil packs but they seemed to think it wouldn't be them because the miss at high revs is extremely aggressive..
Has anyone else had similar problems...
I really can't think of anything else it could be apart from the coil packs..
Edited by so_tred
https://www.sau.com.au/forums/topic/203958-r34-cant-boost-above-10psi/
hi mate I had a simular problem in my s15 I was running a turbosmart boost controller which was spiking to the shithouse! I was running bout a bar which is close to the factory boost cut and soon as it spiked almost went flying through the window everytime.....not sure if this is your problem surley the facroty boost cut isnt around 12psi on a 34 is it?
I didn't think Nissan's had boost cut as such, don't they just hit R&R when too much boost is being fed?
But I figure it's not that because they had the SAFC & SITC to work around R&R if that was it.
Oh yeah, not sure whether this makes any difference or not but I was told when he was trying to get it to run at 10psi it was making 195rwkw..could this amount of power be triggering something..? like something reaching max..injectors, afm?
Edited by so_tred
if the issue is from when the avcr was installed, i got another suggestion for you, get your self a hks adjustable wastegate actuator and bolt that on in replacement of the stock actuator. remove the avcr ad tune the safc with that actuator set at 12psi. i personally wouldnt go more than 10psi to conserve turbo life, but thats up to you.
have u tried removing avcr and running standard boost? problem dissappear? avcr could be prob.
also actuator is a cheaer and less 'cop bait' way of raising the boost and they are able to raise the boost and have no boost spike issues.
If you car is making 195rwkw it is not running 10psi.
I have my car tuned on .75 of a bar and that is appoximately 10psi my car makes 184 rwkw and has no prolems at all.
i have a wlbro fuel pump, AVCR, turbo back exhaust, splitfire coil packs, platinum plugs and FMIC.
I found that when i had the AVCR installed my car was all ove the place when boosting, but have since taken it in and had i tuned properly and now have a great power curve and a reliable car. Note that they could not put anymore boost in as the factory computer was dumping timing and fuel with anymore boost.
cheers cheez...
i got mine on the dyno yesterday, and with the catback, pod and slight boost increase (however by peak power the boost had dropped back to standard so its not really any use for my power figure) my car made 161.2rwkw. I was showed a place where my af ratios are way too rich and if tuned out they said it makes the car alot more powerful through the revs.
not trying to steal the thread just thought i would ad my contribution
I just checked the coil packs and it doesn't appear to be them so can cross that one off the list..
Next to check is the AVCR..
after that I'm stuffed for ideas..
Edited by so_tred
It was making 180rwkw without raising the boost & just a full 3" exhaust so I have no doubt he was able to get 195 on 10psi while also tuning the safc & sitc..
Must agree with sam, the safc with a good tune will surely be enough for the extra 11kw...
The only issue that i can figure is that the standard computer is fighting your SAFC, as my car was dumping timing and fuel with anything over 10 psi.
This maybe the same problem that you are having as my dyno graph looks terrible before i had it tuned correctly with the AVCR and great up to 10psi but all over the place again after 10 psi.
Luckily enough i have a power fc waiting to go in the car to remap everything, but i was told if i didnt have this a could go down the path of a FCD to fix the issue but it was not advisable.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
