  • Replies 204
Yeha that beat sonic is for the a/m stereo... not sure what it does however but enough about him
moar about what wire is for the antenna amp power :)
I am trying to remember what I did.
The power for the antena I picked up of the one of the wires at the back, purple keeps ringing a bell.
I ran the power for the tuner from the cigarette lighter.
what the gooligooo goo is this thing.. its in behind the navi unit where i have a jungle of wires
google gives me no love
theres been an aftermarket radio in there at some stage. that is a bose integration piece to get the TV/navi audio back into the aftermarket unit. its a $300 piece!
(I sell them.)
ok all good, everything works ok power wise. but the picture no good.. is on ntsc also.. was on pal as i trialed it in my room before the car
set it on NTSC and it will work. thats a standard thing with those tuners.
  • 1 month later...
Hi guys,
I was unlucky enough to get my Axis without a Nav unit. However I was lucky enough to find a V35 half cut with a system installed that I was able to swap out for $300. I have pretty much everything except the TV antenna's. I have wired the DVD unit to the screen(as I had to cut the loom and have that working minus the TV tuner and CAN(yet to be connected/wired). I would like to connect a carputer running Centrafuse, and TV tuner into the system. Control for the carputer will be via a 6.5 or 7" touch screen digitizer mounted onto the factory screen. Any help would be appreciated. I have the V35 NAV system manual/wiring schematics if anyone else needs to venture down this path.
A little trick I picked up tonight was how to reset your Airbag light when it flashes faulty. I disconnected the yellow plug on to of the glove box by mistake.
1.turn key on untill airbag light goes out
2.turn key off for over 3 sec
3.repeat 4 times
4.fault code is reset.
Cheers
Matt
Hey chris, i've still not got that tv thing working..
tho my antenna wires are way too short and i have to work out something to do there..
i'll try get the antennas connected and see if it will work..
true. unless I have you confused with someone else you had the OEM navi with a Alpine TV tuner and bruno was doing the job alongside a few euro cars at a peugeot dealership.
if that was you then the things not going to work. if its not then I'm confused.
  • 3 months later...
Decided to give this a try once more.. fixed my short antenna cable problems..
Using an external House Tv i have it set on Pal and things are great..
switch it back over to NTSC the tv in the M35 still does not work properly. image is all over the place and unreadable at times.
Aspect ratio a problem? I've tried every setting i can possibly try on the unit.
Cant seem to get the tv working at all. i am guessing its a problem with my M35's tv?? could that box on the previous page be causing problems??
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
