March 2 - SDMA Hillclimb - http://www.sdmahillclimb.com/
March 8 - Dyno Day
March 8 - Drift school day at Oran parks skidpan - $450 full day using their Silvia and 180sx - [email protected] or you can call 0406669635
March 9 - Motokhana MG Car Club, Canberra. Contact Kevin Kirk 62314617(H) or 0402314617 [email protected]
March 16 - Shannons Wheels, Lawns of Old Parliament House
March 30 - SDMA Hillclimb
April 5 - SAU ACT Skid Pan see thread http://www.skylinesaustralia.com/forums/Sk...ar-t207565.html to enrol
April 13 - NSW Hillclimb Championship @ SDMA Hillclimb track
April 27 - SDMA Hillclimb
May 4 - SAU Texikhana # 1 (updated date) http://www.skylinesaustralia.com/forums/-t212941.html
May24 - AUTOsports Track Day - Wakefield Park - http://www.autosports.com.au/forum/showthread.php?t=1887 (need to register)
May 25 - SDMA Hillclimb
June 08 - NSW Hillclimb Championship @ Grafton - Mountain View - Round 4 http://www.hillclimbnsw.com
June 21 - SAU Track Day at Wakefield Park
June 21st/ 22nd - Autosalon Show Series 2008 - Sydney - http://www.skylinesaustralia.com/forums/Au...ml#entry3626055
July 13 - SDMA Hillclimb
July 13 - [ida] Drift Day - Wakefield Park, Goulburn - http://www.skylinesaustralia.com/forums/id...ie-t215183.html
July 27 - Cruise http://www.skylinesaustralia.com/forums/Ac...Ca-t228134.html
July 26 & 27 - Skyline Nationals Shepparton, VIC - www.skylinenationals.com (website out of date, but gives you an idea).
August 03 - NSW Hillclimb Championship @ Ringwood Park (near Raymond Terrace) - Round 5 - http://www.hillclimbnsw.com
August 17 - SDMA Hillclimb
August 24 - MG Car Club Canberra Motorkhana
Sept 14 - SAU Texikhana # 2
Sept 14 - NSW Hillclimb Championship @ Huntly (Wollongong) - Round 6 - http://www.hillclimbnsw.com
Sept 21 - SDMA Hillclimb
Oct 05 - NSW Hillclimb Championship @ King Edwood Park (Newcastle) - Round 7 - http://www.hillclimbnsw.com
Oct 19 - SDMA Hillclimb
Nov 16 - SDMA Hillclimb
Nov 23 - Marques in the Park
Let me know if you want me to add anything else.
https://www.sau.com.au/forums/topic/203973-2008-dates-for-your-calendar/
Its simple, fun and lotsa Skylines, still need your CAMS or AASA licence - if you go CAMS you don't need L2S, just L2, but for the price difference, the L2S is better value and gets you into the Hillclimbs tooooooo.
Its at Sutton Road (driver training area and skid pan), has a bit of skid pan and might use the back track, although they should be able to get the bike training area this time (I suspect).
There is a bit in the NSW forums about them - If you have any questions, let me know and I'll find out.
  • 1 month later...
  • 3 months later...
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
