The ecu has a set threshold voltage for boost cut, however that volatge must be reached by a certain percentage of the time frame. This eliminates boost spikes and transients setting off the limiter. A boost cut defender stops the ecu seeing past a peset voltage or frequency limit. It is easy for the BCD to be set to low and lean out ur mixtures, because the first time it is set you might not get boost cut for a few days but the load the car up going up a hill and set it off. Subsequently the BCD defender get adjusted more still which in turn reduces your maximun fuel enrichment. So then the car starts leaning out and either goes bang or ur smart enough to do something about it so you increase ur fuel regulator pressure which gives you more fuel up top but stuffs up th rest of your rev range......as u can c u end up chasing ur tail. This is why we call it a patch fix.
I have a r33 with a high flow t3 turbo (vl turbo)
hks exaust
medium front mount
CAI
i get boost cut on 12psi every time. If i install a Turbo smart type II BCD could my car run up to 18PSI without a SAFC ?
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
