Hi all,
Had a search - I've never looked into driveshaft upgrades for my 33 gtst - I'd like to know if 33gtr driveshafts are a bolt in into a 33 gtst.
If not I'd like to just replace the cv's in mine - looks like you have to pull them out and take them to a specialist though? Has anyone here done them themselves? I've fixed up commodore driveshafts before and that was a mission!
Cheers
https://www.sau.com.au/forums/topic/203983-r33-gtr-driveshafts-into-r33-gtst/
driveshafts wont bolt up to stock gtst, ive recently changed to a complete gtr rear end (shafts, diff, axels etc etc)
if u compare the size of each model you'll then realise its worth it ( if u have the power to break them)
Ok - no not the tail shaft the driveshafts from diff to hubs. Anyone here though done up the '33 driveshafts? I'm making 260ish rwkw and would like to start going through driveshafts, wheel bearings etc as it's done over 100000k's and I hate breaking things on the road.
Cheers
  • 3 weeks later...
Cheers
With r32 i know u have to change the whole rear cradle as the shafts dont go into a stock gtst diff. I assume this would be the same for 33. Best bet is to get a whole rear cradle from a wrecked 33gtr.
  • 1 month later...
thats the same with R34's as Adam (abo bob) did the same with his 34.
So speaking of drive shafts - besides swapping the whole rear cradle (looks like thats the only way to get GTR drive shafts in) what are other replacement drive shafts?
Mine need replacing... lol
I did the conversion on adams car some time ago.
Basicly you need the diff, shafts and the hubs. The rest all bolts straight up to the GTs-t. you do need to swap the yoke on the front of the diff but its one bug nut so nothing difficult.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
